turn signal problem
Car: 88 camaro rs
Engine: stock 2.8L V6
Transmission: stock
Axle/Gears: stock
turn signal problem
I have no turn signal response, the hazards work but no turn signals inside or outside the car
anyone know what might be the problem or know where i can find a fuse layout?
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: turn signal problem
Sounds like the flasher module under the dash has failed. There are two, one for turn signals and one for hazards. IIRC, the turn signal module is secured by a clip attached to the steering column in the vicinity of the fuse block, the other is in the convenience center with the horn relay and door chime (keys in ignition, lights on, etc). It looks like a round, silver can with two leads attached.
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
ok cool ill check that tomorrow, WAY TOO COLD to go mess around with it now
also i have a problem with the cigarret lighter shorting out when i plug the cigarrete lighter in. any ideas on that?
Most likely the socket itself, it's easy enough to replace once you remove the small panel it's installed in. I've replaced them in both of my Camaros. If you get a new one, you may have to ditch the old connector and splice on the connector or wires that come with the new one.
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
any one know where ican get pictures of where exactly the turn signal relay is?
i cant find it, its either not there or im blind as a bat
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Turn This Way
The turn signal flasher is clipped on the fuse panel, as delivered from the factory.
However if it has been replaced it might just be hanging in the maze of wires.
You can turn on the flasher then hopefully it will click and help you locate it.
Happy Racing!
8 Wheels Corner Better Than 4, If Youre On The Outside You Have Fair Warning
Happy Racing!
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
Re: Turn This Way
u are very right, i finally located the thing tucked up under the dash above the right fuse box. now i gotta get it out from behind a support
Car: 92 Camaro RS
Engine: turbo 5.3
Transmission: th400 with 3500 stall
I have the same problem but mine keeps blowing the fuse , do you think its the relay?
Transmission: 765R4
I B 2 Fast 4 Turn Signals
If it blows you will know the short is in the circuit before the flasher.
If it doesnt blow you will know the short is in the circuit after the flasher.
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Car: 92 Camaro RS
Engine: turbo 5.3
Re: I B 2 Fast 4 Turn Signals
ok , well i would do that now but its -3 here so i have to wait , but everything else works i thought the hazards are on the same flasher
Transmission: 765R4
Nope, the hazards function uses a different flasher.
Happy Racing!
Happy Racing!
Fronzizzle
Mar 18, 2019 08:29 PM
