So, I wired my fan, fuel pump, electric choke, and my HEI Distributor to my pink ignition switch wire coming from my key. The Fuel pump, choke, and dizzy wire all have 11V when the key is on, but the problem is here..
The fan will work before the key is fully put to run, at .80VDC. When I give the fan relay coil 12V, it shuts off.. Now, I didn't wire it directly to the fan, that's stupid, I used the existing Fan relay on the fire wall. I ran the 12V to the green coil wire for the relay.. What did I mess up?!
Not even an idea?
The fan relay has four wires going to it. Pin D
is brown with white stripe wire that is hot with key on, F is the green with white stripe wire from the fan switch. E is the fat red wire that is the positive lead, and A is the fat black with red stripe wire that sends 12 volts to the fan positive side. That's how mine works, hope it helps
Which one is going to be my coil? I can't figure out what I screwed up.Originally Posted by henryd3
The fan relay has four wires going to it. Pin Dis brown with white stripe wire that is hot with key on, F is the green with white stripe wire from the fan switch. E is the fat red wire that is the positive lead, and A is the fat black with red stripe wire that sends 12 volts to the fan positive side. That's how mine works, hope it helps
Quote:
Excuse my apparent stupidity, but what do you mean by which one is going to be your coil ?Originally Posted by Kevman
Which one is going to be my coil? I can't figure out what I screwed up. Quote:
I was confused, the coil of you relay is the magnetic 'Switch' that brings in your contacts..Originally Posted by henryd3
Excuse my apparent stupidity, but what do you mean by which one is going to be your coil ? Reading the print I have for the wiring of my car, I didn't notice that the devices that activate the relay are Normally open switches that go directly to ground, I'm used to temperature devices being before the relay..
So, if you want to start your fan from your ignition switch, run the Dark green/white wire directly to ground
Yep, that will do it. With the key on the fans will constantly be on. Or put a switch between the wire and ground with wiring running into the car and you have an off/on switch with the key on.
Quote:
I'm considering a thermal switch I can mount on the surface of the radiator to come on around.. 100*F.Originally Posted by henryd3
Yep, that will do it. With the key on the fans will constantly be on. Or put a switch between the wire and ground with wiring running into the car and you have an off/on switch with the key on. Quote:
Why not install a temp switch in the head or intake like the early cars had without computer control of the fans had?Originally Posted by Kevman
I'm considering a thermal switch I can mount on the surface of the radiator to come on around.. 100*F. http://cgi.ebay.com/ebaymotors/SPAL-...item43a4d1648f
That looks nicer, I'll look into one of those babies.Originally Posted by vetteoz
Why not install a temp switch in the head or intake like the early cars had without computer control of the fans had?http://cgi.ebay.com/ebaymotors/SPAL-...item43a4d1648f
Quote:
Plenty of choices out there ; both in price and temp ON /OFF rangeOriginally Posted by Kevman
I'll look into one of those babies. The Spal switch I listed is one of the cheaper ones and a quality unit
Found it cheaper here @ $23
http://www.racerpartswholesale.com/c...n_Accessories2
Is also available in 185 / 165F range
Yeah, that kind of heat range makes good sense. 100 degrees is insanely low
