Is anyone currently working with the hatch pulldown motor?
Old Feb 8, 2011 | 06:50 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
I need help guys with my wiring. I just got a cargo cover with a trunklight. But as I looked around for a trunk light switch, I couldnt find anything to connect to. So does anyone have a picture of the trunk light switch as well as a picture of the wiring to the trunk light that I can use as a referrence? I already searched and looked over a few wiring diagrams but I have not found any success on finding the connection and the trunk light switch. Thanks in advance guyz.
Old Feb 9, 2011 | 12:47 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Car Go 2 Go
If you want the cargo light to illuminate simultaneously with the hatch light, connect the cargo light wires to the red wire with a WHITE stripe at the pull-down, and the other cargo light wire to the black wire with an orange stripe.
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Old Feb 9, 2011 | 12:53 PM
Re: Is anyone currently working with the hatch pulldown motor?
Thats the thing though, I dont have a hatch switch or a hatch light. I picked it up at the junkyard. So Im gonna cut out a square in the cargo cover. I assume that ur reffering to the interior dome light. But I will take your advice and check it out later on today. Then Ill give you a heads up on what I find. Ill take pictures too. Thanks for helping my out man. Much appreciated.
Old Feb 9, 2011 | 02:11 PM
NINÅ's Avatar
Transmission: 765R4
Car Go 2 Go
No, I was referring to the Hatch Light, which is located in the rear most panel of the car.
If you don’t have a pull-down unit, that changes things.
In that case you DO want to use the Dome Light circuit.
A good place to tap into that is one of the pin switches.
So, connect one of the cargo light wires to any hot wire, and connect the other cargo light wire to the white wire coming off one of the pin switches.
Happy Racing!
Old Feb 10, 2011 | 02:24 AM
got her done. check it out.
100_2086.jpg?t=1297325919
100_2089.jpg?t=1297325985
in the picture below, I found that the white wire is connected to the reverse switch at the very top of the pulldown motor assembly.
100_2088.jpg?t=1297326007
100_2090.jpg?t=1297326109
100_2092.jpg?t=1297326155
100_2093.jpg?t=1297326203
IMG00029-20110209-1612.jpg?t=1297326226
IMG00030-20110209-1612.jpg?t=1297326276
Old Mar 5, 2011 | 07:29 AM
maccamenzies's Avatar
Car: 1988 Transam
Engine: 5litre
Next to the rear catch and to the left if your are standing behind looking towards the front of care, what is the panel on top that looks like it is housing 4 contacts?
Old Mar 5, 2011 | 07:34 AM
The 2 outer are for the third brake light. The 2 inner are for the rear defroster lines if your glass is equipt.
Old Mar 5, 2011 | 07:41 AM
Car: 1988 Transam
Engine: 5litre
do you have a close up of the top as i think mine is missing something to connect to it. Im in Western Australia and this is my first American project car that my wife and i are restoring. Im a mechanic but without a manual some items are a bit hard to follow but getting there.Already repaired the pop up headlights.Im inpressed with the American quality though.Makes a change from japanese cars.
Old Mar 5, 2011 | 07:44 AM
Car: 1988 Transam
Engine: 5litre
Just worked it out i think the bottom of the hatch has contacts that mate with the contacts in the bottom panel?
Old Mar 5, 2011 | 07:48 AM
I'm at work right now. But when I go home, ill provide some video for you.
Old Mar 5, 2011 | 07:54 AM
Car: 1988 Transam
Engine: 5litre
Thanks a lot i appreciate it.Trying to find a transam club in my town which i think i will b struggling to find so the internet is helping heaps with info for repairing and restoring my transam.Will post pics when i can.
Old Mar 5, 2011 | 11:31 AM
Yup. That's how it works. Now on the passengerside lift ( the support lift for the hatch glass) there should be a wire with a female terminal connector. That female connector connects to the male terminal that is welded on the lift. Those terminals serve as a ground point for the third brake light and defroster lines.
Old Mar 5, 2011 | 05:23 PM
Car: 1988 Transam
Engine: 5litre
Ahh. Yes I see now. Thanks. I opened up the rear locked boot compartment and found the original log book, owners details and some original receipts for some work done by the dealer back in 1990. Even had a invoice for it 40 thousand service in 1990. Was amazing to have those.
Old Mar 5, 2011 | 10:52 PM
Car: 1988 Transam
Engine: 5litre
Had a look at mine and can not see any contacts where that plate meets up.Will take a photo and upload.Still working out how to upload a pic as well here.
Good news is i went out and got some parts off the guy that was left behind.Grabbed the original steering wheel which i thought would have the push buttons but it dosent.(Has a Pontiac emblem on the horn centre).
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
