fix didn't work
Old Feb 12, 2011 | 12:13 PM
fonzie85's Avatar
Car: 89 IROCZ
Engine: Forged 347 LS1
Transmission: Built 4L60E with 4k stall
Axle/Gears: 4th gen w/ 3.42 gears
fix didn't work
Hello all... I have an 89 iroc with a 350 tpi. The tach was reading too high all the time, I tried the tach fix by replacing the capacitor and it is still the same. Any body have any idea as to what could still be wrong with it.
Thanks,
Old Feb 14, 2011 | 03:33 PM
fonzie85's Avatar
Car: 89 IROCZ
Re: fix didn't work
no body has any ideas on this?
Old Feb 14, 2011 | 03:50 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Inna Terrible Fix
There is circuitry in the dash near the tach.
It’s contained on a small plug-in PCB or integrated in the main board.
Also on the PCB you’ll see a resistor chip.
Desolder pins 4 & 10.
Use a 500K potentiometer.
Solder it across traces 4 & 10.
Move the potentiometer to half way.
Start the engine and compare the tach reading with a test equipment quality tach.
Dial it in, unsolder the potentiometer, measure it and install a matching resistor.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
Old Feb 14, 2011 | 04:17 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Inna Terrible Fix
Happy Racing!
NINA, why cant he just leave in the 500K pot?
Old Feb 14, 2011 | 04:20 PM
Re: fix didn't work
Never mind. I didnt realize that they are huge.
Old Feb 14, 2011 | 06:13 PM
fonzie85's Avatar
Car: 89 IROCZ
Re: fix didn't work
thanks for the info but i only know enought with electrocis to dangerous... can you put this in dummy terms for me?
Old Feb 14, 2011 | 08:21 PM
Re: fix didn't work
take a look at this picture. https://www.thirdgen.org/forums/atta...-dscn2812b.jpg
This is the board that needs to be modified (pins 4 & 10).
To better understand the process of fixing the issue at hand, your gonna have to read the info. The info is very valuable for repairing the tach.
https://www.thirdgen.org/forums/elec...meter-fix.html
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mustangman65_79
Sep 1, 2015 03:51 PM
TheJoeY88
Aug 13, 2015 06:51 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
