Switched to a Carbed 350.. Temp gauge no longer works
Old Feb 28, 2011 | 01:02 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
The gauge worked before I rid my car of the awful TBI, I rewired most of the gauge sensors, the Oil pressure works, tach works, speedo works, voltage reading works, but my temp gauge doesn't read anything.
It's a yellow, and a black wire to a 3/8 thread sensor that went into the intake on the TBI, I moved it into the head.
Did I accidently use the wrong sensor?
Old Feb 28, 2011 | 01:53 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Made No Sense
The temp gage wire was originally was dark green, one wire only emanates from the sender.
The sender was located on the left, below the valve cover, on most VINS.
Sounds like you used the wrong sensor.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
Old Feb 28, 2011 | 02:12 PM
Kevman's Avatar
Engine: 2004 LQ4
Re: Made No Sense
Happy Racing!
Yea, I probably am.. Damn..
Old Feb 28, 2011 | 02:16 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Made No Sense
The one on the intake was the Coolant Temp Sensor for the ECM. Need the single wire temp sender for the guage. Replacements are readily available at the parts store for not much $.
Old Mar 2, 2011 | 04:23 PM
Kevman's Avatar
Engine: 2004 LQ4
Re: Made No Sense
Which harness does it come from? Does it come out of the driver side, or the pass?
Old Mar 2, 2011 | 04:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Made No Sense
The wire you seek is dark green as mentioned - there is a large harness that runs from driver side to pass side, around the back over the bellhousing. The wire exits from that harness, just about at the rear of driver side head, and it ran up and over the intake in a small plastic loom.
Old Mar 2, 2011 | 05:14 PM
krazefbird's Avatar
Car: 84 Firebird
Engine: currently 1968 307
Axle/Gears: 3.23 lim slip
Re: Switched to a Carbed 350.. Temp gauge no longer works
So, I think it is the green wire that is connected, the temp gauge used to work but now dosn't. Is that a bad sensor?
Old Mar 3, 2011 | 06:31 AM
naf's Avatar
naf
ground the wire with the ignition in 'run' and the temp guage should peg full hot
this would indicate a possible bad sender
the senders themselves seldom go bad though
it's just a simple thermistor
Reddeath210
Oct 6, 2015 08:20 AM
justin57
Aug 20, 2015 07:05 PM
86IROC112
Aug 17, 2015 02:00 PM
Irocohio
Aug 12, 2015 08:03 AM
marcusaw
Aug 10, 2015 08:13 AM
