HELP, turn signal problem on my 90 rs
Old Mar 8, 2011 | 12:48 AM
cHEVy hEAVy's Avatar
Car: 1989 IROC Z
Engine: 5.0 tpi. stock [for now]
my turn signals worked just fine, but i decided to take off my lenses & try to buff them out, i took my bulbs out too just to keep them safe, once they were buffed, i reinstalled the bulbs then put the lenses back on (didnt screw them in yet) then i turned on my parking lights to see the diffrence the buffing made they looked super good so i screwed in the lenses. then i was on my way to the store & tried to use my turn signal & instead of the light blinking on and off the arrow just lit up and stayed lit up. not exactly sure if it was just a dumb mistake that i made somewhere or what.. any ideas?
Old Mar 8, 2011 | 01:21 AM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Re: HELP, turn signal problem on my 90 rs
Lol the same thing happened to me when i tried to polish them junk stock signal lenses and my lights started doing the same thing? By the way how did you polish them? i let my soak in hot soapy water all night and there still foggy? I'm about to buy some cheepos off ebay i guess anything would be better then this ****.
Old Mar 8, 2011 | 01:50 AM
Car: 1989 IROC Z
they have kits to clean plastic headlight lenses that get fogged up at auto part stores (advance, pepboys etc) i used one of those (just followed the directions) and it was better, but not good enough so then i took rubbing compound and rubbed it in on both lenses then let it sit for about 10 mins then buff it off. i compounded & buffed each lense 4 times, then after that i used this bottle of Plastic Renewer & Protectant. its supposed to protect from UV rays as well & that was like the cherry on the top of the sundae lol they look wayyyyy better, not absolutely Perfect but its close, it seems like the plastic was brought back to life again. im also eventually going to invest in new ones but i wanna get really nice ones and im too broke for that right now haha and now i dont feel so bad using these for a whilee
Old Mar 8, 2011 | 08:18 AM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
check your bulbs (all the signal bulbs) if they are fine my next suggestion would be the flasher mine went out of the blue a couple weeks ago i was omw home from the body shop and had no signals lol changed all my bulbs a couple were bad but still had the problem ended up being my flasher
Old Mar 8, 2011 | 05:42 PM
Car: 1989 IROC Z
ahhh thanks! where is the flasher located? so i can get a new one.
Old Mar 8, 2011 | 06:33 PM
have heard people talking about them being in a few spots i can say mine was if you look under the steering column on the ride side of it where the obd1 plug is unscrew that plastic piece and there should be a silver like bracket attached to it about it going diagonal and mine was clipped on that diagonal bracket i could probably describe it better or walk you through to it on the phone easier so if you can't figure out what i tried to type then pm me and i will send ya my #
Old Mar 8, 2011 | 06:48 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You blew a bulb - if one side flashes but other doesn't, you blew a bulb on the side that doesn't flash.
Flasher is where fuse panel is - there are 2 flashers, one for the 4ways and one for the turn signals.
Old Mar 8, 2011 | 07:09 PM
again like i said in my car it was not at the fuse panel but above the convenience center
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
