vss non-cable speedometer not working?
Old Mar 27, 2011 | 09:46 PM
james.gould150's Avatar
Car: 1991 z28
Engine: 305 tpi
Transmission: 700r Automatic
issue with my 91 z28 i pulled and replaced the vss and still no read on the dash...and i cannot find anywhere that sells the gears for the speed sensor (although mine looked fine when i pulled oout the old sensor... im lost and im alsomst ready to throw a tarp ove rthe car ive had sooo manyy electrical issues with her S.O.S PLEASE HELP ME
Old Mar 27, 2011 | 09:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: vss non-cable speedometer not working?
IIRC ,
in 91 the VSS signal goes to computer 1st then to the speedo.
check that wiring
Old Mar 27, 2011 | 09:52 PM
Car: 1991 z28
Engine: 305 tpi
can this be done via multimeter? or should i visually inspect wires? ughhh this dash is a pain int the ***** to disassemble any suggestions on how to check properly? i dont wanna half *** anything
Old Mar 28, 2011 | 04:17 PM
Pocket's Avatar
Car: 91 Trans Am
Please do check it with a meter. Saves you a TON of time. Test resistance to make sure the wires are connected
Here is the circuit
http://www.austinthirdgen.org/mkport...F_and_vin8.jpg
Old Mar 28, 2011 | 05:59 PM
Car: 1991 z28
Engine: 305 tpi
Here is the circuit
do i look for ohms or volts?
Old Mar 28, 2011 | 06:12 PM
Car: 1991 z28
Engine: 305 tpi
bump
Old Mar 28, 2011 | 06:38 PM
Pocket's Avatar
Car: 91 Trans Am
Resistance
Put a lead on the beginning and end of the wire to test everything in between. A result of 1 (open circuit) or several hundred (short/bad connection) means problems. You want a low number say 20 or under for a good connection
Old Mar 28, 2011 | 06:55 PM
Car: 1991 z28
Engine: 305 tpi
Resistance
i dont wanna sound like an idiot but do i check from the plug at the vss on trans or elsewhere? it is only two wires that come from the plug do i test that?
Old Mar 28, 2011 | 09:25 PM
Car: 1991 z28
Engine: 305 tpi
TTT
Old Mar 29, 2011 | 04:33 PM
Car: 1991 z28
Engine: 305 tpi
bump
Old Mar 29, 2011 | 07:40 PM
Pocket's Avatar
Car: 91 Trans Am
Pull the harness and VSS connector up into the engine bay where you can reach it easily
Unplug the ECM and run continuity tests from ECM pins to the connector
If those check out do the same from the ECM to C207 D
If thats ok, repeat from C207 to cluster
If those all check out then the issue is not in the wiring
Old Apr 11, 2011 | 05:44 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
SO, you are saying to put one probe of the meter to the yellow wire on the vss harness and the other to the yellow wire of the vss on the actual pcm? If so, what am i setting the meter to? I assume ohms ,but what setting on ohms?
Old Apr 11, 2011 | 08:25 PM
Pocket's Avatar
Car: 91 Trans Am
Yes, and set it to the smallest resistance setting you have, most have a 20ohm setting
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
ChevyZ71
Aug 13, 2015 07:30 AM
mizz0313
Aug 12, 2015 06:45 AM
marcusaw
Aug 10, 2015 08:13 AM
