Help a Girl out! Brake Lights don't Work!
Old Apr 3, 2011 | 06:51 PM
LTL_DMON's Avatar
Car: 1986 Trans AM
I'm having taillight issues here, when I press the brake pedal the taillights don't come on but when I put on the hazards or turn signals they work fine. They worked fine a few months ago I don't know what could have changed... I just switch out the interior, is it possible something got unplugged? All of the fuses are good, I just replaced a caliper and rotor, the pedal is also extremely stiff. Any help would be great now that I finally have the car insured and registered, I'm ready to get it out on the road! The car is a 1986 Trans AM auto 305 TPI.
Old Apr 3, 2011 | 09:33 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: Brake Lights don't Work; Turn Signals and Hazards do.
check the brake light switch under the dash, could be either unplugged, faulty, or broken....they are very easy to break, especially if you dropped the column down
Old Apr 4, 2011 | 04:42 PM
LTL_DMON's Avatar
Car: 1986 Trans AM
Had my great friend Jim help me and the pedal is no longer stiff brakes work great but the lights still don't. I checked the switch and it's fine. Installed new switch still doesn't light up. Bulbs are brand new 2057s. Fuse is brand new.
Old Apr 5, 2011 | 06:27 AM
Car: 91 Trans Am
Engine: 355 TPI
sounds like a bad wire or ground or something of that nature
Old Apr 5, 2011 | 06:32 AM
ville_valo_05's Avatar
Car: 1985 Trans Am Limited Edition
Engine: 305 tpi
Transmission: 700r w/ stage 2 shift kit
check the groun in the light panel on the back
Old Apr 11, 2011 | 02:10 PM
LTL_DMON's Avatar
Car: 1986 Trans AM
I tested the wiring at the connector, but I get no power reading from the brown wire. I do how ever get power from it when I turn my hazard lights on. Is this problem coming from the from of the car then? I checked the ground wire at the back of the car, but it was just fine.
Old Apr 12, 2011 | 06:43 PM
LTL_DMON's Avatar
Car: 1986 Trans AM
the issue is clearly coming from the front of the car. I was testing the voltage at some of the connectors (the one connected to the steering column) the black wire show no reading when the brake pedal was depressed but there was a reading when the hazard lights were flashing. Is there a common problem that happens with the wiring or maybe a bad ground up there or a fusible link that's gone bad? I know very little to nothing about electrical work so any help would be so very helpful.
Old Apr 13, 2011 | 08:20 AM
Car: 91 Trans Am
Engine: 355 TPI
Re: Help a Girl out! Brake Lights don't Work!
im in the same boat when it come to electrical which is why i pointed you to the switch....this is gonna be a stupid question but, did you check the fuse?
Old Apr 13, 2011 | 08:50 AM
LTL_DMON's Avatar
Car: 1986 Trans AM
I replaced the switch (the old one looked fine though)and the fuse twice just to make sure, and still nothing. I also just replaced the Hazard flasher.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
Omega
Aug 10, 2015 12:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
