Headlight problem ( not the motors )
Old Apr 17, 2011 | 03:40 PM
86t/a305tpi's Avatar
Car: 1986 Trans Am
Engine: LB9 305 TPI
Transmission: 700r4 w/shift kit
Axle/Gears: Borg Warner 9 bolt Posi
I recently bought an 86 Trans am. The headlights were stuck up at the time of purchase. The previous owner said that they got it checked out and the problem was in the switch. I wish he would have been right. I have an 86 pontiac fiero, which has the same switch. I knew that switch worked so I tested it in the trans am. Did not help. I then tested the trans am switch in the fiero and that worked perfectly. So I know it's not the switch. My dad and I have been working on this for way too long now.
The problem: The headlights/tail lights, when turned on, immediately blow the fuse. We disconnected the motors because I have read that those can be the problem. The fuse still blew. We cleaned all of the electrical connections in the c-100. Cleaned all the relays. Checked the fusible links. Everything seems to be ok. We checked the back half of the car as well. No bare wires anywhere to be found. But everytime I try and turn on the lights (even the parking lights) the fuse blows. We are at our wits end. Help is needed!
Old Apr 18, 2011 | 09:33 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Re: Headlight problem ( not the motors )
Take the parking light bulbs out including license plate light and then turn parking lights on.
It could be a very corroded connection in the connector of the bulb holder,you`ll find out soon enough with the removal of the bulbs
Old Apr 19, 2011 | 03:46 PM
krazefbird's Avatar
Car: 84 Firebird
Engine: currently 1968 307
Axle/Gears: 3.23 lim slip
Man that sucks 86TA, wish I had some good advice. Short to ground obviously somewhere I would think. Check the wire bundle up under the headlights and in front of the radiator maybe? Mine has had some corosion and caused some issues. Or possibly just not grounded correctly? That made my headlights not go up.
Now for my problem. How do you tell if the headlight motor is bad? I had the famous one light up and could not get the other up. Thought it was a bad relay so got a new one and that didn't fix it. When I plug in the relays both the lights go down? I disco'd both the relays and rotated the headlights up so I can still drive at night(cops didn't think lights down was cool) So what gives? The motor was hot while I was trying the relay thing, is this a good sign that the headlight motor is bad?
Old Apr 19, 2011 | 03:56 PM
florida_gators's Avatar
Car: 1990 Firebird
I'd open up the headlight control module on the engine side of the firewall and check the board inside. I'm not sure if this would cause fuses to blow if it is bad, but it's worth a look. Just take a small flathead screwdriver and pry the back off to get to the circuit board.
Old Apr 19, 2011 | 04:03 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
He has the 3-wire motors which were used 82-86. No headlight control module. Those were used on the 87-89 and 90-92 with a 2-wire motor.
Lon
Old Apr 19, 2011 | 08:02 PM
Car: 1990 Firebird
Right. Good catch Lon.
Old Apr 26, 2011 | 11:00 AM
krazefbird's Avatar
Car: 84 Firebird
So any ideas on why mine won't go up when I turn them on?
Old Apr 26, 2011 | 11:23 AM
Badasscamaro346's Avatar
Car: 87 camaro
Engine: v8 carb'ed
sounds like the motor is shorted internally. If it gets hot when you cycle the relay then it is getting power but something is holding it in place. If it is shorted internally (from age) then it could just be it grounding itself out inside the case.
Old Apr 26, 2011 | 12:57 PM
krazefbird's Avatar
Car: 84 Firebird
Ahhh I see. Is there a way to fix this or do I need to get a new one? I priced a new one at autozone.....needless to say, I see why people drive around with one headlight up or both up all the time. $100 for a motor? Either side? WTF? You can keep it!
Does anyone have any diagrams?
Old Apr 26, 2011 | 08:04 PM
Car: 87 camaro
Engine: v8 carb'ed
well if it were me (im cheap) I would open it up and see if it is something obvious or easily fixed before trying to buy a new one or hunting for a used one. I did this with mine and it ended up being the contact for the motor slipped down and was touching the windings)
Old Apr 28, 2011 | 08:17 AM
krazefbird's Avatar
Car: 84 Firebird
cool, I will try that, I'm cheap too. Have to do a move first so it will be a bit before I get a chance to. Just wanted to see what I could do if anything. Thanks
Old May 8, 2011 | 01:29 AM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
hey krazefbird: let me know how you go?
Mine is doing exactly the same at the moment, I bought new actuator relays, doesn't go down, but when i plug the relay out and back in, it does :S
I'm thinking maybe the isolation relay, but its only doing it for one headlight...
i can't find anywhere to buy the isolation relay from to eliminate it though :S
Old May 9, 2011 | 06:27 AM
krazefbird's Avatar
Car: 84 Firebird
sure thing evil if I get that far. Getting ready for a move and my tools aren't that accessable and once we get moved not sure how much time I will have, gotta get a new job and all. For right now, I unpluged the relays and just rotated the ***** so the headlights are up. Looks retarded but oh well. Once I get to it I think I might tear apart the motors or something, not sure. Would like to come up with a way to graft them in the down position to eliminate the pop up but I think that is going to take quite a while. Anyway, I will try and let you know as soon as I can and if you don't hear from me and you fix yours, let me know what's up?
Old May 9, 2011 | 02:57 PM
evilstuie's Avatar
No worries. I'm gonna have a tinker this weekend and see what I come up with.
From memory when I was testing it with a test light the RH light harness wasn't getting +12V like the LH one was when the switch was activated, so I'm going to try splicing into the lefthand light and run the wires to the RH relay and see if that fixes it. if it does then its just a dodgy wire somewhere.
Old Mar 31, 2026 | 06:05 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
nothing like replying to a 15-year-old post but hey why not are you as well took apart that board with a magnifying glass look at all your solder it's old and I saw one of mine had a small crack in it only visible with the magnifying glass i took off old and resoldered the connections and it fixed my problem headlights! You know you're dealing with the right board when the label on that board says do not disassemble,
Ghettobird52
Jul 5, 2024 11:18 PM
Fronzizzle
Aug 17, 2015 02:52 PM
stalkier
Aug 13, 2015 12:59 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
