Wiring problem
Wiring problem
I have a 92 that had the positive ground on the battery arced.
The car won't start, fuel pump isn't engaging, windows won't roll down.
But my headlights work.
does the car need a harness now or what?
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Wiring problem
It probably just blew some fuses, check the fuse panel under the dash on the drivers side. It might have blown some fusable links too. Those are the wires with the little black thing that bolt up to the starter.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Wiring problem
Also check the fuse between the battery and the fender. There is a weatherpack there with a single fuse in it, 20 amp - has one orange wire and one red wire.
db057
Aug 11, 2015 10:11 PM
