Car wont start security light goes off
Old May 27, 2011 | 09:39 AM
PTS's Avatar
PTS
Car: 89 Vert Camaro
Engine: 3.8SFI Turbo
Transmission: 200R4
So I've searched for an hour and couldn't find a solution to my problem so im gonna as you guys directly
when i go to start my car it usually starts right up. however sometimes usually when i need to be somewhere it seems lol the car wont crank over and i know if the security light stays on its vats but mine goes off. when i turn the key to start the fan goes off and the radio just like normally but it wont crank
what could be some possible solutions. the guy before me put a hurst shifter in the car and the neutral safety switch is rigged some how i have to look into what he did everything else seems normal
the car is a 91 z28 350
Old May 27, 2011 | 11:23 AM
BladeQuarter's Avatar
Car: 1989 Chevy Camaro RS
Engine: Proud V6 Owner
Transmission: 5 Speed
Axle/Gears: unk.
Re: Car wont start security light goes off
sounds like the starter relay in the drvers side kick panel, i had the same issue, replaced it and it starts fine now
Old May 27, 2011 | 12:24 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Your basically down to the same issues as a pre vats car with the exception of the starter relay... I would replace the relay and see where you stand. Wouldn't hurt to have your battery and starter checked out as well... If you don't have one i would definately reccommend and high torque mini starter... they weigh a fraction of the original starter and use less volts to start your ride and so far mine is pretty much indestructible... but start with the relay... if it's going bad they have a tendancy to "stick" and thats why you aren't cranking...
Old May 27, 2011 | 08:40 PM
PTS's Avatar
PTS
Car: 89 Vert Camaro
Transmission: 200R4
awesome thanks guys ill just get a new one and see what happens since they are probably cheep i dont think thats it though cause i hear it clicking when i go to start it.
Old May 27, 2011 | 08:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'd say look into that "rigged" shifter wiring - on my stock shifter the Neutral Safety Switch doesn't always make good contact, and I get a single "click" rather than an actual start - I've since gotten it held better with tape since there is no problem with my switch or the connector, but rather the way they 'connect' to one another.
Old May 27, 2011 | 09:00 PM
Axle/Gears: unk.
the starter relay is only like $21, so at least its cheap
Old May 28, 2011 | 01:37 AM
atvsjoel's Avatar
Engine: v6
Transmission: 5sp DUH HATE automatics
Axle/Gears: ??
Thread high jack what is a kick panel!!! Is it the plastic and my case fuzzy fabric panel held on with two screws kinda under dash going up and down or is what? my Door relay is in passenger kick panel and I do not think it was behind that rubbery or foam covered hole sorry high jack
Old May 28, 2011 | 07:24 AM
Axle/Gears: unk.
under the plastic panel that your hood release us mounted in, then there is some black tar like goop that they hide the relay in
Old Jul 4, 2011 | 10:13 PM
BrennenK014's Avatar
Car: 1987 Trans Am
Engine: V8 305
Transmission: 700 R4
Are you sure its not an old imobilazer? I had this same kinda issue, when I had gotten my car. It had an imobilzer id turn the key nothing would happen, there would be power but absoloutely nothing happened. I thought it was the starter, I rremoved the starter and tested it, worked fine. Reinstalled it, then I had the bright idea to get a wire and cross it at the starter, I turned my key on and then crossed it at the starter with a wire. Car started right up, I had bought it from an estate after sitting for 2 years, nobody new a thing about the car. It started like a champ when I crossed it, and turns out it was an old imobilizer and they tend to mess up alot. So what I did was just installed a custom push button start
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
