Power Door Lock Relays: How to
Old Jun 14, 2011 | 04:25 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I finally got the power door lock relay for my 86 camaro! Now to install it. What do I need to install this? Is it plug n play or is there anything else involved in installing this relay? Thanks
Old Jun 14, 2011 | 06:04 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Power Door Lock Relays: How to
Are you replacing an existing relay? Adding?
Old Jun 14, 2011 | 07:29 PM
Just replacing the existing relay that is there already that doesn't work anymore.
Old Jun 14, 2011 | 09:46 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Unplug/plug/play. Just be careful not to break any little plastic catches etc.
Old Jun 14, 2011 | 10:27 PM
Done. Unfortunately, now it still doesn't work. The old relay was corroded it seemed and was just nasty looking compared to the new one.
The locks and unlocks click and they partially slide now, but hardly. Not enough to actually lock or unlock anything. Atleast it budges some and I know the relay was actually bad.
Old Jun 14, 2011 | 10:49 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Your gonna have to clean the gunk off the door latch and lube up the
lock rods and latch assembly. The 25+ yo old grease and gunk is
preventing the rods and lock from sliding easily.
Clean them up good with wd-40 spray the lube them up with some
spray white grease.................
Old Jun 15, 2011 | 09:20 AM
I've lubed up the entire door lol. I literally have opened up the doors 3 times to fix this crap. The only thing I have not done yet is remove the latches from the door and clean them. But I guess it is due for a degreasing, then re-greasing!
Old Jul 17, 2012 | 11:57 AM
Ormly's Avatar
WHERE IS THE RELAY LOCATED ON 86 MODEL YEAR GMC ?
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
