Fuse block negative
Old Jul 13, 2011 | 01:58 AM
startat2's Avatar
Fuse block negative
Not sure if this belongs more in the engine swap or electronics but here goes...
I'm currently in the middle of a v6 to 350 swap. I read and kept in tact the driver side of the wiring harness. I have found what I think is the primary power to the fuse block, which was taken off the old starter. The problem I'm having is finding where the primary negative is. In the driver side "pass through" there is a faded wire that could be light brown or a faded dirty black :P It dosn't seem large enough to be a negative for all the running accessories however.
So now for the question, where is the primary negative and what is the best way to wire the fuse block so that everything functions?
It is of note that I'm running a bare bones set up. Lights and windshield wipers
Old Jul 13, 2011 | 11:17 AM
startat2's Avatar
Re: Fuse block negative
Vehicle is a 91 rs
Old Jul 13, 2011 | 03:43 PM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
Um???? The negative is grounded right to the engine from the battery. There is no negative in the fues box. The car is the ground!
Old Jul 13, 2011 | 06:51 PM
startat2's Avatar
Yea, I was reading that there were two main ground points for the battery, and really feel like an idiot :P I need to quit workin till 2 am
Old Jul 14, 2011 | 07:17 AM
Transmission: t-56
Its ok, Sometimes you need to just walk away for a bit. Sometimes your better off coming back the next day when your mind is clear.
gta892000
Aug 11, 2019 11:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
gta892000
Sep 16, 2015 12:37 AM
timonator
Sep 10, 2015 07:55 PM
64goatman
Sep 9, 2015 01:09 PM
