lighter blows acc fuse?
Old Aug 6, 2011 | 09:52 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
I replaced the element in my lighter so it would work, but now whenever I put it in, the fuse blows. I've never had this problem before. The outlet always worked. Is the lighter supposed to pop out when its hot??
Old Aug 6, 2011 | 10:46 PM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
Re: lighter blows acc fuse?
i was havin the same issue. i guess its a common thing for the light housing to short out. i got a replacement one from the auto parts store and wired it up seperetly now it works fine.
Old Aug 7, 2011 | 08:52 AM
chevydrvr's Avatar
What do you mean by wired it separately ?
Old Aug 7, 2011 | 10:04 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yes, lighter supposed to "pop" when hot - if it doesn't, then the lighter or the housing are bad.
Old Aug 7, 2011 | 10:06 AM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Same problem started to happen with mine. Its the outlet it self shorting out. I pulled mine out and the bottom of it I believe there was a tab that was bent and touching other metal causing the short. And I believe Intimidator ment he wired it to its own "circuit" so if it shorts out again, it won't blow the ACC circuit.
Old Aug 7, 2011 | 11:40 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
it a common issue. mine blows anytime i push the cig lighter in, but the outlet works fine for plugging in a phone charger or gps or something like that. good thing i dont smoke
Old Aug 7, 2011 | 01:08 PM
Car: 1987 IROC
i mean i ran mine own seperate fused power and a ground to a new lighter socket.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
usafirebird
Sep 29, 2015 11:58 PM
