Need someone to ID this piece before i cut it off
Old Sep 2, 2011 | 01:56 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
Im trying to remove everything from my engine bay that is unnessesary. i Unplugged this and there was zero difference in the drivability of my car but i dont want to take any chances incase it is vital. it is located behind my clutch fluid resevoir in the corner of the engine bay
What is it?
Original car was a 305 TPI firebird---- Now it is a 350 carbed
Old Sep 2, 2011 | 02:04 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: Need someone to ID this piece before i cut it off
something to do with ignition delay the knock sensor
Old Sep 2, 2011 | 02:06 PM
lunati397's Avatar
Knock control- ESC-electronic spark control. this sends the signal from the Knock sensor to the ECM to reduce the timing if it hears a ping.
Old Sep 2, 2011 | 02:07 PM
lunati397's Avatar
http://www.binderplanet.com/forums/s...ad.php?t=45292
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
Should i reconnect it and leave it there?
Old Sep 2, 2011 | 02:08 PM
lunati397's Avatar
if your carbed then get rid of it beacuse it works with the computer for TPI
Old Sep 2, 2011 | 02:09 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
i believe my computer is still in the car. does that still mean i can get rid of it?
Old Sep 2, 2011 | 02:11 PM
lunati397's Avatar
it may still be in the car but im sure its not in use for engine control most carb setups are stand alone so power and ground and it reads off the engine mechanically
you can toss it and it will not effect your motor
Old Sep 2, 2011 | 02:14 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
thanks
gta892000
Aug 11, 2019 11:16 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
ericjon262
Sep 11, 2015 06:07 PM
FormulasOnly
Sep 6, 2015 10:42 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
