Help please gauge problems!!
Old Sep 9, 2011 | 10:39 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Ive used the search but had no sucess. The problem is i recently put Leds in the gauge cluster and now the Tach only goes up to 3.5K rpm. It just hangs there when i rev it up. Also the Temp guage doesnt work. Now all of these worked right before i removed the cluster. I made sure every thing was connected good and still no sucess.. Any ideas?? I also removed the individual gauges from the cluster at one point. But i replaced them the same as i took them out. Thanks for any advice the Tach dosent bother me its the Temp Guage that I NEED to fix Pronto!!!
Also its a 1991 camaro 3.1L
Old Sep 12, 2011 | 03:56 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Temper Tantrum
With the engine OFF, but the key in the RUN position, ground the sender wire, then look at the temp gage.
What does the gage do when that wire is grounded?
Happy Racing!
If You’re Passed By Your Own Tire On The Track, It’s Time For A Pit Stop
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
justin57
Aug 20, 2015 07:05 PM
