starter kill switch ?
Old Sep 19, 2011 | 02:10 PM
ctoledo0834's Avatar
Car: 87 camaro Z28 convertible
Engine: 350 carb
Transmission: th-700r4
Axle/Gears: Posi traction 3.42 gears
I wanted to install a kill switch in my 89 and wanted to know how I can do this and what I need ?
Old Sep 19, 2011 | 06:16 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: starter kill switch ?
Waste of time; any good thief can jump a starter.You only need to put a screwdriver across the terminals on starter and it bypasses any switch you have
Better to install a cut out on Ign ( coil ) or fuel.
Much harder to bypass if done correctly
Old Sep 19, 2011 | 06:44 PM
Engine: 350 carb
So how can I go about doing that then?
Which ones better the fuel or coil one?
Old Sep 19, 2011 | 07:11 PM
ramosj88's Avatar
Car: '88 IROC-Z
Engine: 5.0
Transmission: TH700-R4
Old Sep 19, 2011 | 07:41 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If you run a wire ( hidden in the factory harness so it looks like stock ) from coil Neg terminal to ground through a switch then if someone hot wires the coil direct from the battery ( most common way to bypass the Ign switch ) then they will get no spark.
Edit
As the white wire from coil Neg goes to tacho you could splice into that wire under the dash to achieve same result without adding any visible wiring in engine bay
Or you find the wire that goes to the elec fuel pump and put a hidden cutout switch on that.
Old Sep 19, 2011 | 09:59 PM
Engine: 350 carb
Ok so I already know which wire the fuel pump is so all I have to do is connect a switch to the wire and ground it ?
Which one is the coil ?
Thanks for the help
Old Sep 20, 2011 | 04:03 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
No
all that will do is make a direct short to ground and blow your fuel pump fuse ( if you don't have a fuse your car may burn down )
You cut the pump wire and put a switch in ( connect both cut ends to switch ) to turn the pump off or on
Old Sep 20, 2011 | 09:11 AM
Engine: 350 carb
Yea I have a fuse that's by the headlight.
So a normal toggle switch is fine ?
Old Sep 20, 2011 | 09:12 AM
Engine: 350 carb
Should I install another fuse With the switch?
Old Sep 20, 2011 | 11:41 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
All circuits should have a fuse somewhere ( as close to supply point as possible).
If you have added extra wiring then you should have it fused
Old Sep 21, 2011 | 04:21 PM
murukalo's Avatar
Car: 1988 Camaro RS
Engine: 355
Transmission: TH-350
Axle/Gears: 4:10
Do like I did and make one for each one
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
383cam
Sep 9, 2015 06:01 AM
luvofjah
Sep 3, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
