That sound when you leave lights on won't stop...Help!!
Old Sep 27, 2011 | 11:43 PM
leedavidalan's Avatar
Hey guys I have an 89 Iroc. When my headlights are on that annoying sound (when your car is off and you leave your headlights on) starts happening and won't stop, even when im driving. Something wrong obviously and I'd rather just kill that sound. Where is the wire and what color is it? What fuse is it?
Thanks guys
Old Sep 28, 2011 | 12:04 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: That sound when you leave lights on won't stop...Help!!
bump..
Old Sep 28, 2011 | 12:12 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
On a 91 it is located under the dash on the drivers side next to the console. You will have to remove the lower dash panel thats under the steering wheel. The actual buzzer is a black box that will be in a fuse box and can simply be pulled out.
Old Sep 28, 2011 | 12:13 AM
thanks Camarotucker. I'll try that!!
Old Sep 28, 2011 | 12:14 AM
any pictures perchance??
Old Oct 29, 2011 | 05:52 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
I know this is an older post, but what caused this? The buzzer itself?
I got the same problem Just started today, and i want to Fix the problem not avoid it by hackin things out lol
Old Oct 30, 2011 | 02:41 AM
Yeah dude it was the buzzer itself. When you remove the fuse cover, the buzzer is to the right and kind of in the back. With a phillips screwdriver remove what you must to expose the buzzer. If I remember correctly you can simply just pull it off with some effort, and voila, the annoying sound is gone forever!!
Old Oct 30, 2011 | 11:43 AM
Car: 1991 Camaro RS
Well! I found the issue!! after looking at wiring Diagrams for 697 minutes and a headache from hell, i found it!
For some reason after 187482 Miles, The buzzer is Staying on because of the seatbelt. all it it has to do is retract a few inches... doesn't have to be Locked in. I wear my seatbelt from time to time. so it looks like all the time now hahaha
Old Oct 30, 2011 | 02:07 PM
wow thats kinda random haha. the only good thing about the buzzer is it reminds you to turn off your headlights, something a goof like me could use every now and then.
glad you're good to go man
Old Oct 30, 2011 | 03:41 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
its supposed to beep at you when you first start up the car if you dont have your seat belt on, so the seat belt is wired into the buzzer. after i did my engine swap, it buzzes constantly unless you buckle up. i ALWAYS wear my seat belt so its not a big deal for me. and a good laugh when anyone else gets behind the wheel.
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
