grounds behind dash?
Old Nov 2, 2011 | 11:36 PM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
hey guys last night i was driving and the road was bumpy, well my lights headlights and cig lighter, and dome lights do not come on no more. but some times i start the car and the lights come back on temporarely. so i checked my fuses in the fuse box and they were good. i havent check all my grounds up front cause i cant find a good ground diagram. but i did read that theres some type of grounds behind my dash that i figured i should take a look at. well thanks guys.
Old Nov 3, 2011 | 11:05 AM
Car: '90 Camaro
Engine: 305 tbi
Re: grounds behind dash?
so i searched a little more, and i came to the conclusion that the headlight control switch is bad, either that or my fuse for the 20 tail fuse. or jst a bad ground wire.so i shall see today!
Old Nov 4, 2011 | 11:22 AM
Car: '90 Camaro
Engine: 305 tbi
sooooo... no one has a clue?
Old Nov 4, 2011 | 11:53 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
sounds like the head light switch, and maybe a fuse for the cig lighter or a worn out receptacle. two separate issues
Old Nov 4, 2011 | 02:02 PM
Car: '90 Camaro
Engine: 305 tbi
uh whats a receptacle? and thanks
Old Nov 4, 2011 | 02:10 PM
Engine: Lb9
Transmission: M20
receptacle - an electrical (or electronic) fitting that is connected to a source of power and equipped to receive an insert
Old Nov 4, 2011 | 08:02 PM
Car: '90 Camaro
Engine: 305 tbi
ok haha learned something new haha.
well i have bought two head light switches and they both were broke, first one i bought a oriellys and the other at advance but they both were made by the same company. im starting to think its a ground cause i opened my door and my dome came on after i drove with the hls on but no lights.
Old Nov 5, 2011 | 12:16 PM
Car: '90 Camaro
Engine: 305 tbi
ok i have a question, my alternator is overcharging, could it be that i need to get a new one and also i was searching and a post from '02 came up nd i read that it could be a fusable link on my starter, could this be my problem?
Old Nov 7, 2011 | 12:01 PM
Car: '90 Camaro
Engine: 305 tbi
are there any relays that could have something to do with this problem????
MantyZ28
Nov 8, 2015 06:54 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Glowsock
Sep 5, 2015 07:48 PM
Ian Irvine
Sep 4, 2015 08:08 AM
andy74
Sep 3, 2015 08:41 AM
