want to turn my low beam headlight into a hi/low
Old Dec 8, 2011 | 07:17 PM
imRICH23's Avatar
Car: 88 vert iroc & 95 586hp trans am
Engine: 355
Axle/Gears: 373
i know ill need the new housing and bulb thats a hi/lo... but is it that simple? or will relays and other electrical components be needed?
Old Dec 8, 2011 | 08:59 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: want to turn my low beam headlight into a hi/low
if you have four low beams everyone will assume your bright lights are on.
Old Dec 8, 2011 | 09:03 PM
imRICH23's Avatar
Engine: 355
Axle/Gears: 373
Figured I didn't explain it right.. I want to switch to one bulb that control hi and lo. Then get rid of the old hi beam bulb.
Old Dec 10, 2011 | 12:36 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
youd also have to mod the stock wiring or make your own harness.
Old Dec 10, 2011 | 12:43 PM
skinny z's Avatar
The wiring shouldn't be difficult. The question is: Is there a single 6.5" by 3.9" available that has both low and high beam?
Old Dec 10, 2011 | 03:47 PM
imRICH23's Avatar
Engine: 355
Axle/Gears: 373
Cut my end of the harness and wire in the new in do new headlight bulb? Figured it was that simple, just didn't know for sure.
Old Dec 10, 2011 | 04:14 PM
travis401's Avatar
Car: 91 Camaro RS
its a lot mroe involved then simply cutting a plug off and adding a new plug. you have to wire the high beam function into the low beam spot since theyre not connected. itd be easier to just make an entirely new headlight harness that taps into the dimmer switch and runs off the battery via relays.
Old Dec 10, 2011 | 04:27 PM
imRICH23's Avatar
Engine: 355
Axle/Gears: 373
Yeah that past my comfort level including the relays. Anyone know how to properly wire something like this?
Old Dec 10, 2011 | 04:29 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
wait.... you're going to have 4 headlights... but two won't be functional, and two will operate as both high beams and low beams?
or are you talking about changing the headlights to a one piece unit? (which is a nice look if you can pull it off)
Old Dec 10, 2011 | 04:32 PM
travis401's Avatar
Car: 91 Camaro RS
im thinking hes wanting to go from a 4 light to a 2 light system and use the space for something else like air induction.
Old Dec 10, 2011 | 04:49 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Just rewire it to be like a Firebird, which is Hi/Lo in 2 bulbs. Just hafta find a 5"x7" (iirc the Camaro size correctly) headlights.
Or aren't 2 of the Camaro headlights are a Hi/Lo function anyways ? Can't you just use those 2 & pull the other 2 Lo Beam only light openings for your CAI?
Old Dec 10, 2011 | 04:50 PM
imRICH23's Avatar
Engine: 355
Axle/Gears: 373
^^^correct
Old Dec 10, 2011 | 04:51 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
That's what I read too. If that's the case, just remove the inside pair (high beam only) and tuck the connector away. The outer pair is HI/LO, so high beam is still available. If going to H4, a harness upgrade is still necessary.
Old Dec 10, 2011 | 04:53 PM
travis401's Avatar
Car: 91 Camaro RS
o yea, i forgot the outers were high/lo, i was thinking they were high only.
Old Dec 11, 2011 | 05:50 PM
skinny z's Avatar
I think that the outers aren't really hi/lo. That's to say, if the outers were all you had for headlights, you'd find the hi beams lacking.
Old Dec 11, 2011 | 06:00 PM
travis401's Avatar
Car: 91 Camaro RS
im sure if thats the case, that they make a 4x6 true high/low beam. but then again who knows. if it where me, id skip using sealed beam hologens altogether and retro fit a bixenon HID projector in a housing able have a single HID hi/lo on each side.
Old Dec 11, 2011 | 06:24 PM
skinny z's Avatar
That would be the way to go. Does such a kit exist?
Not to take over this thread, but the reason I replied is because I have an interest in using one of the headlights sockets as a CAI as has been suggested.
If there is any info available regarding this kind of mod, I'd like to see it.
Outer headlights as a high/lo beam unit with the inner buckets used as a source for cold air.
Old Dec 11, 2011 | 06:27 PM
travis401's Avatar
Car: 91 Camaro RS
no kit, you have to make it yourself
Old Dec 11, 2011 | 06:28 PM
travis401's Avatar
Car: 91 Camaro RS
there is a company that makes projector 4x6 housing, but its low beam only.
Old Dec 11, 2011 | 06:41 PM
Car: GTA
The 82-90 Firebirds use a 5x7 & the 91/92 Firebirds use a 4x6. So just grab a set of lights for a 91/92 Firebird & try those.
Old Dec 11, 2011 | 06:43 PM
travis401's Avatar
Car: 91 Camaro RS
really, the 91/92 birds switch the the 4x6 light? i did not know that.
Old Dec 11, 2011 | 06:48 PM
Car: GTA
Yep. Same headlight door but smaller bulb & bigger plastic surround to cover the extra 1"s from the smaller bulb.
Old Apr 8, 2012 | 03:42 PM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
I was thinking about the one piece headlight conversion.
I think the lights would come from a GMC truck don't they? Just go to a wrecking yard pull the lights / harnesses and mounting panel then just glass up a Frankenstein panel to make it fit right?
or am I not seeing an easier way?
1992CamaroGirl
Dec 25, 2017 08:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
novaderrik
Aug 10, 2015 12:44 PM
