electrical issues
Old Dec 12, 2011 | 03:09 PM
91blue5.7tpi's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4th gen..3.23 posi
electrical issues
let me start by saying that my fusible links are good. now, i have no power to the lid, tail, and sir fuses. if i run a juper wire from a a good spot on the fuse box to one of the above mentioned fuses, they work w/ no problems (except for super slow blinkers). any ideas of a solution? is it bad/dangerous to run the jumper wire to a good spot? thanks for any help
Old Dec 12, 2011 | 03:30 PM
crazymonkey16's Avatar
Car: 1990 Camaro RS
Engine: L05 TBI
Re: electrical issues
The great thing about electrical issues is that your problem could literally be anywhere in the car. I hope you've got an ohm-meter, because you're gonna be using it a lot. I don't have a wiring schematic handy, but I don't recall any common wires between those three... you're saying that if you bring power/ground to those functions *after* the fuse, they all work? Are any of the fuses blown, or were they blown and replaced? If any of them are/were blown, you could have a short anywhere behind the fuses in the circuit... the only way I know of to find an electrical issue is to start at the battery and check every wire, every connection with an ohm-meter (and visually, if you can) all the way back around to where it grounds to the body. Look for anyplace that might have gotten hot and melted wires (in my '90 RS, dozens of wires run right over the exhaust manifold, and 3 of them were melted through. -.- ) and places water could've gotten... but don't rule anything out until you've positively tested it. One other thing - make sure you plan for plenty of time to find the problem, because you never know how long it'll take, and if you're on a time crunch you overlook obvious problems.
Old Dec 12, 2011 | 04:12 PM
Car: 1991 Z28
Engine: 5.7 TPI
thanks, yea i have an ohm meter. what gets me, is if i supply power to one of the fuses (via a jumper and working fuse) all three of the fuses have power at that point. its almost like there is a common power for all 3 (like an outlet, how you only have to hook power to one side). to make a long story short.......supply power to one of the fuses that doesnt work, and all 3 will work. it seems like i might have a short somewhere between the fuseblock and the firewall. i say this b/c with everything normal, i have power to every fuse except for the 3, when i supply outside power via a different fuse, all is well. ugh...let the hours of work begin
Old Dec 12, 2011 | 11:01 PM
Car: 1990 Camaro RS
Engine: L05 TBI
:P yeah, unfortunately there's no way (that I know of) to make electrical troubleshooting any easier/faster. Post when you find the problem, or with further updates though.
Old Nov 23, 2012 | 06:07 AM
1988 djpatrick's Avatar
Car: 1986 Camaro IRoc/Z28
I knw this thread is almost a year old but I'm having the SAME EXACT PROBLEM! It sucks! Did u ever resolve the issue? Can u tell me what u did?
Old Nov 26, 2012 | 04:31 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Link Think
You have a bad Fusible Link located at the Starter, or a bad or corroded connection going to it.
Happy Racing!
I Didn’t Jump The Start, The Flagman Was Late
Old Nov 26, 2012 | 05:26 PM
What does the fusible link look like. Is it a wire with a black cylinder shaped thing on the wire?
Old Nov 27, 2012 | 04:36 PM
NINÅ's Avatar
Transmission: 765R4
Link Think
Yes.
Happy Racing!
Old Nov 27, 2012 | 04:54 PM
rob_deep's Avatar
I need help I have a 1986 camaro sport berlinetta and my dash gauges don't work (temp battery and oil) there is a couple loose wires under the hood but i don't know where they go too and my fuses are fine. Cigerette lights doesn't work. Either.
Old Nov 27, 2012 | 05:00 PM
Thanks. I'll replace them. Hopefully that's the problem
Cornholio7979
Sep 20, 2018 02:31 AM
Gambit TA
Sep 1, 2015 07:27 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
mizz0313
Aug 12, 2015 06:45 AM
