Trunk motor will not work **help**
Old Jan 19, 2012 | 02:10 PM
kplums17's Avatar
not sure if it needs replaced or if somthing is wrong
1989 firebird
Old Jan 19, 2012 | 08:17 PM
JTS's Avatar
JTS
Car: 83 Z28, 85 Burb
Engine: 305 Carbureted
Transmission: 5 Speed
Re: Trunk motor will not work **help**
If I remember right, the firebirds have an inline fuse that's down by the fuse block.
The next step would be to find a voltmeter/tester and see if there is power back there. I think the wire you want to check is a red with white stripe, but I'm not 100% sure. Hopefully someone else can help with that. You will have to remove the interior panel back there to get to the wires. Also, do a search, I think there is a wiring diagram on here too.
Old Jan 19, 2012 | 09:01 PM
lethaldomestics's Avatar
subscribed. I need to know the also. The motor is intact but not working. Mines a 1987
Old Jan 21, 2012 | 12:00 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Check the Tech Article on Thirdgen.org that I wrote to repair the hatch pull-down units. It is under the General Repairs category. If you need any parts I have them available.
Lon
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
bryan623
Aug 10, 2015 11:33 AM
