Help identifying plugs
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
What are these plugs for and is there a link or someone have the diagram for these connections.
Its the main harness that connects to the internal harness, sorry I dont know the name of the connectors.
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Help identifying plugs
The first picture looks like the connectors ( Black Ones ) for the harness to the rear which is the C208. The white one I think is for cruise control
Second pic the clear one looks like the plug that goes behind the gauges, C1 I think. the grey one might be for the antenna relay
Its hard to guess what they are without knowing where they are located in the car
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Picture 1 shows the dash harness BLACK C207 connector,...... I forgot what the WHITE one is for ( Fuel Injection ?)
Picture 2 shows The ECM harness C207 Connector. I forgot what the GREY one is for ( Fuel injection ?)
You might have already guessed,..... the WHITE plugs in pic 2 connect into the BLACK plugs in pic 1. AND The GREY plug in pic 2 connects to the WHITE plug in pic 1. VERY common for these plugs to be disconnected after a Carb swap.
The round connector in pic 3 is for the oil pressure gauge. I'm not sure about the BLACK 2 pin plug,.......... maybe to the wiper motor ?
Linson
Sep 21, 2015 01:08 PM
89 formula TPI
Sep 7, 2015 11:06 AM
