High beam / blinkers issue help plz !!
Old Feb 23, 2012 | 06:14 PM
Annihilated911's Avatar
Car: 91 z28
Engine: 5.7 350 TPI '91
Transmission: World class T-5
Axle/Gears: Stock ??
Im having the same problem ive read about here on alot of camaros. My high beams wont switch on/off unless i tilt my steering comumn, which ive read here means i need to re attach the metal rod in steering column. My question is, my blinkers or haz lights wont work at all. Could these two problems be connected and what can i do to fix blinkers???
( and yes i changed bulbs out first)
Old Feb 24, 2012 | 12:13 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: High beam / blinkers issue help plz !!
Im having the same issue as well accept high beams turn on and off but only one of them. Turn signals just stay on and the indicator on the dash either stays on on doesnt come on at all. I got new bulbs in the front completely. I got a put new ones in the rear still but any ideas
Old Feb 24, 2012 | 12:39 PM
Car: 91 z28
Do your blinkers work when you use them for HAZ lights?
Old Feb 24, 2012 | 12:46 PM
6SIX6's Avatar
Car: 89 IROC
nope i dont think so they just stay on
Old Feb 24, 2012 | 02:40 PM
Car: 91 z28
Check the fuse. Then check the bulbs i fixed mine by changing all bulbs the PO had a wrong bulb type causing them to not function
Old Feb 28, 2012 | 01:35 PM
6SIX6's Avatar
Car: 89 IROC
I think that might be the issue as when I had the tail lights they didnt have the orange turn light bulbs. Ill try it out this weekend and see what happens
Old Feb 29, 2012 | 01:11 AM
Lippard9202's Avatar
Car: 1986 Iroc
Transmission: 7004r :(
I had problems with my high beams not wanting to switch on unless I moved the steering wheel. got the column tight, clicks fine now. on the same night I fixed the column, my back 2 turn signals/hazds went out.. bulbs were fine, replaced them anyways though. front ones come on, but just stay on, haha. oh well. should'nt be too hard to fix.... (words I'm hoping to not regret)
Old Feb 29, 2012 | 02:23 AM
Chris89FBForm's Avatar
Car: 1989 Firebird Formula
Engine: 305 TBI (For now?!?!)
Transmission: Auto-Stock
Axle/Gears: stock
As for the turn signals, there is a good chance that your flasher is dead. Ik on my 90 Jeep XJ I had my turn signals would just stay on. its like a 5-15$ part and its really easy to install..
Old Mar 1, 2012 | 09:14 PM
Car: 1986 Iroc
im sorry, a "flasher"?
Old Mar 1, 2012 | 09:18 PM
Axle/Gears: stock
It's a part you rarely have to replace. but yes it's called a Flasher. It's just an over glorified Capacitor. here is what you are looking for http://www.autozone.com/autozone/par...r=6413_0_7281_
Old Mar 2, 2012 | 01:32 PM
6SIX6's Avatar
Car: 89 IROC
I will try that as well as I have a few of them kicking around the house from previous cars
GTAman
Mar 15, 2019 11:40 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
inferno15
Aug 29, 2015 01:48 AM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
