Electrical issue when key turned to start
Old Mar 24, 2012 | 01:56 AM
NC-88's Avatar
Car: 88 Sport Coupe
Engine: 383
Okay, so a little about the car. Originally 1988 305 TBI, now it is a 383 carb, no ECM.
Had a holley 670 on it and it ran fine. Then I got antsy and decided to try out a holley 750. Car cranked, but I could never get the 750 to start...so I slapped the 670 back on for now. Went to start it up and all you hear is a click then all lights go out and all electrical power is gone, no cranking what so ever.
Battery is a fairly new interstate. Like I said this exact set-up ran perfectly fine before I messed with the carbs.
I unhooked the battery, let it sit, hooked it back up and electrical power came back (dome light on). Go to start it and same thing, once that key hits start position I lose all electrical power. All my grounds are good. I am stumped as to why it would crank w the 750, but cut out completely with the 670 back on.
Old Mar 24, 2012 | 02:12 AM
NC-88's Avatar
Car: 88 Sport Coupe
Engine: 383
Re: Electrical issue when key turned to start
Going to charge battery overnight and try again tomorrow...
Old Mar 24, 2012 | 07:23 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
It sounds like the battery needs to be charged up, let us know if that worked for you.
Old Mar 24, 2012 | 09:06 AM
zombienerd's Avatar
Car: 1982 Firebird Base
Engine: 2.8L V6
Axle/Gears: Stock
I'm with Edward. That definitely sounds like a dead battery to me. Just toss some jumper cables on it, you'll know pretty darned quick
Old Mar 24, 2012 | 10:26 AM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Make sure your cables are nice and tight at the battery and starter. And make sure they aren't corroded.
Old Mar 24, 2012 | 10:46 AM
NC-88's Avatar
Car: 88 Sport Coupe
Engine: 383
Tried it this morning, same thing. Battery is fully charged and I made sure the terminals were clean. I guess the starting circuit has circuit breakers somewhere along the line?
Old Mar 24, 2012 | 11:07 AM
zombienerd's Avatar
Engine: 2.8L V6
Axle/Gears: Stock
Well, if the ECM was removed, there's no telling what you have for wiring.
Here's the wiring diagram for your year (body).. It shows the ignition wiring path in the lower right. IF it's not been changed.
http://austinthirdgen.org/mkportal/m..._continued.gif
Old Mar 24, 2012 | 11:13 AM
zombienerd's Avatar
Engine: 2.8L V6
Axle/Gears: Stock
How are you positive that the battery isn't the fault? Did you attempt a jump, or just going off the fact that you had it on the charger?
If the battery is bad, being on the charger all night wouldn't fix it. This also doesn't rule out a possible bad battery charger.
The only way to rule out the battery completely is to hook it up to another running vehicle with jumper cables and see if you can get it to turn over at all, or borrow the battery from said vehicle, if it's compatible.
Old Mar 24, 2012 | 11:35 AM
NC-88's Avatar
Car: 88 Sport Coupe
Engine: 383
Guess I had to get the + terminal spotless, because I cleaned it and cleaned it and just about when I had ruled that out she cranked. RUNNING like a champ now....off to dial in the TV cable from bowtie overdrive.
Thanks for the quick reply guys, I'm so glad thirdgen.org exists, wouldn't have been able to do this 383 project without you guys.
Old Mar 24, 2012 | 11:37 AM
NC-88's Avatar
Car: 88 Sport Coupe
Engine: 383
You called it zombienerd
Old Mar 24, 2012 | 01:16 PM
zombienerd's Avatar
Engine: 2.8L V6
Axle/Gears: Stock
Glad to have helped! Those terminals can look clean and still give bad connections Especially if they're factory terminals, inside the sealed plastic can look Horrible!
Old Mar 24, 2012 | 04:26 PM
Edwardgp's Avatar
Engine: 454-350
Yes sir off and running glad we could help, let us know how fast she is but don't kill yourself doing it.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Jae992
Aug 27, 2015 09:07 AM
mizz0313
Aug 12, 2015 06:45 AM
ZsTransAm
Aug 11, 2015 07:30 PM
