PLEASE HELP ME WIRE AFTERMARKET TACHOMETER!
Old Apr 4, 2012 | 10:06 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I am trying to install my aftermarket tachometer but somehow I am getting something wrong and it will not turn on. So does anyone have any special places where I can connect the power cable, ground, and switch cable? and I am also uploading a pic of my distributor cap but I am not sure into which on to tap into, PLEASE HELP...
Old Apr 6, 2012 | 03:21 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Big Tach Attack
What is the brand and part number of the tach?
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Old Apr 6, 2012 | 03:46 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: PLEASE HELP ME WIRE AFTERMARKET TACHOMETER!
thats some shabby lookin wireing! kinda looks like an old tach filter on the firewall?
Old Apr 7, 2012 | 05:52 PM
calgutie's Avatar
Car: 1984 Z28
I am lost with this tach and I am kinda giving up on it unless someone can help me wire it...
Old Apr 7, 2012 | 07:35 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The terminal for the TACH output right on the coil you took a picture of.
Most generic tach wiring, Red +12v switched, black ground, white TACH, green illumination.
I guess literacy isn't for everyone. Nina asked what brand tach you have and you just complain instead of providing any relevant information for someone to help.
Clearly you have an Accel supercoil which, you can find install instructions online for.
If you know the brand of tachometer, you could put some effort into finding install instructions for it too. A bit of reading and you could solve your own problem.
I agree with joe, too. Scotchlocks can burn in hell.
Old Apr 7, 2012 | 08:27 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Your tachometer should have four wires.
1. +12 volts (switched) - Connect this wire where it will get +12 volts when the key is ON.
2. Ground -Connect this wire to -12 volts (negative side of the battery). A metal bracket under the dash will do.
3. Ignition signal - Connect this wire to the wire with the brown connector at the distributor (in your photo).
4. Illumination - connect this wire to someplace that get's +12 volts when the headlights are on. OR you can connect it to the same place that the +12 volt wire is connected to (the light will be on all the time.
You'll need the installation instructions to the aftermarket tach to be able to tell which wires are which.
Old Apr 7, 2012 | 08:31 PM
BrianChevy's Avatar
Car: 1987 IROC Z/28
Engine: 5.0L TPI. Custom Tune
Transmission: 5 Speed/ Pro5.0 short /hurst stick
Axle/Gears: 1LE 10 bolt Rear/T2R 3.45 PBR/disc
A few years ago I went thru some problems of my own with a Tach and I documented it here in a thread for future thirdgen owners. Give it a try and see if it helps you out.
https://www.thirdgen.org/forums/elec...ml#post1327434
AND if it works out well for you, then PAY IT FORWARD by doing something to your car, figuring something out that isn't on the board, DOCUMENTING it and sharing it with the wonderful people here on THIRDGEN.ORG
Thanks!
Brian
Old Apr 14, 2012 | 01:51 PM
johnf123's Avatar
Car: 1992 RS vert
Engine: forged 383
Transmission: a busted one for now ;)
Axle/Gears: 4th gen 3.73
i wired mine into the coil..just lift one of the connectors up, there will be two female connections and one male connection, i just stuck the wire in the unused female
Old Apr 14, 2012 | 07:21 PM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
Wire for lights-run to fuse panel for dash lights, tach feed- i hooked mine to the white wire under the dash for the stock tach since it probley doesnt work anyways, ground and hot wire is pretty easy to figure out
Street Lethal
Apr 30, 2019 12:14 PM
LittleFranks
Sep 17, 2015 12:22 PM
ChevyZ71
Aug 13, 2015 07:30 AM
ZsTransAm
Aug 11, 2015 07:30 PM
