no lights no horn no dome light no trunk pop no dash light please help
Old Apr 14, 2012 | 10:25 PM
BmoreKnight's Avatar
Car: 1984 Trans Am
Transmission: 700 r4
Axle/Gears: Rear Wheel Drive
hello I have a 84 trans am and i hooked a set of fog lights for my kitt replica but hooked them into the turn signals for when u put the lights on that would come on but i guess it was to much amp for everything and now i have no lights at all meaning the lights won't flip up, no dome light, dash lights, horn, no trunk popper or radio. I pulled down the fuse box to check it and all the wires r fine and put brand new fuses in it and still nothing. I also changed the headlight switch and still nothing. does anyone know what could be wrong like relays or something like that or has someone had the same problem with no lights or nothing and what u did to fix it
Old Apr 14, 2012 | 10:42 PM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
Re: no lights no horn no dome light no trunk pop no dash light please help
a relay?
Old Apr 14, 2012 | 10:54 PM
Car: 1984 Trans Am
they have headlight relay and horn relay but wanna see if anyone knows what it could be before i spend the money on the stuff
Old Apr 14, 2012 | 11:33 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
All of your symptoms say it's the ACC fuse in the fuse block. Not sure about the headlight motors, but everything else is in the ACC fuse.
Old Apr 14, 2012 | 11:35 PM
Car: 1984 Trans Am
where is the acc fuse located at? or do u mean the fuse box
Old Apr 14, 2012 | 11:46 PM
Al Hasse's Avatar
Yes, in fuse box, I called it a block, because it is. The fuse is labeled ACC for accessory.
Old Apr 14, 2012 | 11:55 PM
Car: 1984 Trans Am
u mean the little silver ones in the fuse box cuz if so i replaced them also or is is something else
Old Apr 15, 2012 | 12:25 AM
Al Hasse's Avatar
No, it's a yellow 20 amp fuse, it may be labeled CTSY. In my car it sits right next to the metallic circuit breakers. If not the fuse, then check up the line to your fusible links (makes more sense because your light motors don't work either), there are about 3 at the starter, and a couple more on a distribution block on the passenger side radiator core support - will more than likely be at the starter.
Old Apr 15, 2012 | 07:57 AM
Car: 1984 Trans Am
i'm gonna send u my number cuz not really sure where to look for them at and if u could please call me pm sent
Old Apr 16, 2012 | 09:48 PM
oSnooZe's Avatar
Car: 1984 Chevy Camaro
I was wondering if you figured out the problem because im have the same problem with my 84 camaro
Old Apr 19, 2012 | 09:51 AM
Car: 1984 Trans Am
yes i did i took it to B&W Electric and it was 3 fusible links from the starter so that should be ur problem but Al I thank you also cuz u were spot on about the wire to the starter being bad
PATRIOTIC1911
Sep 1, 2015 07:26 PM
Jae992
Aug 27, 2015 09:07 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
