gauge illumination issue
Subscribe
Apr 17, 2012 | 10:08 PM
After I installed my new radio, none of my gauge illumination lights come on when I turn my headlights on its pitch black only my turn signals and warning lights come on and the fuses are all good
88TA
Reply 0
Apr 18, 2012 | 06:00 AM
Re: gauge illumination issue
Quote: After I installed my new radio, none of my gauge illumination lights come on when I turn my headlights on its pitch black only my turn signals and warning lights come on and the fuses are all good
Any chance you inadvertently dimmed the gauge lights?
JamesC
Reply 0
Apr 18, 2012 | 08:05 AM
Yea that was one of the first things I checked
Reply 0
Apr 21, 2012 | 08:00 PM
I have no power at the fuse......
Reply 0
Apr 23, 2012 | 05:34 PM
Light Fight
Quote: I have no power at the fuse......
We assume you meant the INST LPS fuse.
If the “parking” lamps illuminate, your problem is a bad connection FROM the switch internals where the connection is made to the potentiometer TO the input side of the aforementioned fuse.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the green wire at the headlight switch when the “parking” lights are on.
Is there power there?
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
Reply 0
May 27, 2013 | 10:11 AM
Sorry for the long delay but yes it does have power at the switch but still no lights
Reply 0
May 28, 2013 | 08:29 AM
So I found out I'm an idiot and missed the gray "illumination" wire that was stripped and sitting off to the side in my radio pod for some reason. What could that've shorted out?...
Reply 0
May 28, 2013 | 04:19 PM
Light Fight
Quote: ……yes it does have power at the switch but still no lights
If you have no power on even one side of the fuse your problem is a bad connection from the green wire at the switch to the input side of the aforementioned fuse.
For example, a broken or disconnected wire.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Reply 0
Jun 7, 2013 | 11:00 AM
Does the gray illumination wire HAVE to be connected for the dash lights to work? My pioneer doesn't have an illumination wire
Reply 0
Jun 10, 2013 | 04:35 PM
Light Fight
Quote: Does the gray illumination wire HAVE to be connected for the dash lights to work? My pioneer doesn't have an illumination wire
No.
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Reply 0
Subscribe
