Sequential Turn Signals - batch 7
Old Jul 7, 2012 | 07:33 PM
  #101
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Sequential Turn Signals - batch 7
Originally Posted by BluFBdy
BTW these instructions are deceiving, I'm on the under dash mod and idk if I have it right, am I supposed to be splicing the blue and white together just bridging the circuits or am I supposed to be connecting the brake wire leading to the lights (not the switch side) to the white wire?
I'm PM-ing you my house number, feel free to call. Or you can Skype me too, either is fine.
Lou
P.S.: This write up has pictures: http://www.austinthirdgen.org/index.php?pid=37
Old Jul 7, 2012 | 07:59 PM
  #102
BigBadLou's Avatar
Engine: TPI
I like the hot glue idea its actually pretty smart, e-tape could break down but unless somone deliberately cuts up the glue the board is safe lol i sent you a pm prematurely asking the same question, my tail lights are identical to yours i believe you were my inspiration for it actually lol if i could get the 194 to light up while still being a functional running light i would be happy with it lol i thought of swapping out the socket also but idk if i wannt cut up the frame to do that lol would it be possible to put a resistor in line and trick the circuit to accept the 5v bulb?
i think ill attempt to wire it up as it is, should i cut the + to the 194 and just run it to the unit or should i simply tap into the + on the 194 and run it to the unit with a diode?
For the corner lense, I would recommend an extra bulb (with an extra socket). Nobody makes dual filaments in that size. It would mean, of course, making a small hole into the tail light plastic to get the socket in, nothing we can't handle.
Not sure what you mean by a 5V bulb, all bulbs on cars nowadays are rated for 12V.
I wouldn't hack the 194, as per your PM earlier. I would leave it in. And as I mentioned, I would add an extra socket with an extra bulb. The one worry I have is that if the bulb is too big, it will be too close to the lense and might melt it.
Sorry about the vague instructions, I will amend them.
You need the blue wire that you already cut off (as far away from the switch as possible) and you will splice it somehow into the white wire. I said "connect" in my instruction because the method is your choice. You can put a little male/female connector there, you can solder it, you can put a clamp on it, your call.
Call me if you have more questions.
Lou
Old Jul 7, 2012 | 09:42 PM
  #103
83 Crossfire TA's Avatar
hey Lou, am I on your list?
Old Jul 7, 2012 | 09:58 PM
  #104
BigBadLou's Avatar
Engine: TPI
Now you are.
I am trying to set up a Google Store with Google Checkout and it is taking more time than I expected.
If anybody wants to either mail a Money Order or can do a direct transfer GIFT payment via PayPal, PM me for details because I now have plenty of units pre-made and ready to go.
Lou
Old Jul 8, 2012 | 11:00 AM
  #105
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Axle/Gears: 3.42 Detroit locker
ok Lou. I will be sending out payment soon I hope. Just waiting on the money to clear through.. the boss. lol
Old Jul 8, 2012 | 11:56 AM
  #106
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
BluFBdy, would be very interested i seeing how yours works when you get it hooked up. Think you could upload a small video when you are complete? The reason I ask is I am getting one too and want to see how these look on our camaros. Thanks and sweet car btw.
Old Jul 8, 2012 | 02:18 PM
  #107
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
http://www.youtube.com/watch?v=8lW-4vIS7XA hope this helps
Old Jul 9, 2012 | 08:45 PM
  #108
BigBadLou's Avatar
Engine: TPI
89newfun, no worries, I have plenty of units now. I understand how this whole boss situation works, been married long enough.
Dabesiv, thanks for the link, that looks very nice! (I realize it's not your car)
Old Jul 13, 2012 | 05:44 PM
  #109
BigBadLou's Avatar
Engine: TPI
David, your payment arrived tonight. I will deposit it first thing in the morning and catch the mailman to drop off your unit with him.
I have an STS unit on my own Mustang. So your Mustang buddy is sure welcome to buy one.
Oh, was that supposed to be a secret? OOPS!
Old Jul 14, 2012 | 05:49 AM
  #110
Sdi1000's Avatar
Car: 1980 Pace Car, 1987 Trans Am
Engine: 4.9 Turbo, 5.0 TPI
Just recived my units. I would like to thank BBL for making another batch of these up on request, exellent service, fast and low cost shippment over the pond. Really nice to do buisness with you, first class !
Old Jul 14, 2012 | 10:01 PM
  #111
Dabesiv's Avatar
Awesome thanks! any idea on ETA of the unit?
Old Jul 14, 2012 | 10:25 PM
  #112
BigBadLou's Avatar
Engine: TPI
ETA for your QTH is CCA WED.
Old Jul 19, 2012 | 11:33 AM
  #113
Dabesiv's Avatar
The unit came in today! For some reason i was expecting something much bigger than what it is. Where can I find the instructions on how to install this?
Old Jul 19, 2012 | 11:51 AM
  #114
BigBadLou's Avatar
Engine: TPI
Glad to hear!
The instructions are on my STS page, just scroll down to the end.
Old Jul 19, 2012 | 03:20 PM
  #115
Dabesiv's Avatar
Glad to hear!
Thanks Lou. I did searching and found it earlier. I'm under the dash now. Can't find the brake switch. Any idea what the colors the wires are? You show colors for firebirds but not camaros
Old Jul 19, 2012 | 03:27 PM
  #116
Dabesiv's Avatar
Or if you could. Give me a call since its hard to type on the iPod while crammed under the dash.
Old Jul 19, 2012 | 05:19 PM
  #117
BigBadLou's Avatar
Engine: TPI
1982 Berlinetta? Now that will be harder, I do not have any diagrams for that car, sorry.
What does your repair manual say? The brake switch is right on the brake bracket and has usually 3 wires.
My only 1982 diagram (not even sure if it's a Berlinetta or which model) shows only two wires: orange and white. That system, though is only for vehicles with integrated rear turn signals and brake lights. Berliettas don't have that, so my diagram must be for a 'Bird.
I'll give you a call in a minute. You might want to edit your post and remove your number to prevent spambots from collecting it.
Old Jul 19, 2012 | 06:28 PM
  #118
Dabesiv's Avatar
no just to double check, i was supposed to splice into the white wire with the blue wire from the brake correct?
Old Jul 19, 2012 | 06:37 PM
  #119
BigBadLou's Avatar
Engine: TPI
Yes, the blue wire coming from the brake switch needs to be connected to the white wire. That's all.
I updated the instructions online too, thanks for the feedback. Hopefully the new Camaro-specific diagram will help. Please let me know.
Lou
Old Jul 19, 2012 | 06:46 PM
  #120
Dabesiv's Avatar
Lou
are you sure thats all i need to do for wiring? haha judging by the diagram this is a 5 min wiring job.
Old Jul 20, 2012 | 04:39 AM
  #121
Dabesiv's Avatar
i take that back. it still took some time to do it, i got it to legal standards but its not functioning well. would it be better to ask for help on here or in a pm?
Old Jul 20, 2012 | 05:50 AM
  #122
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
Hey, BBL. I added a center taillight which lights up as a brake light and the wings work as directionals. Would this still work if I installed your STS?
Attached Thumbnails Sequential Turn Signals - batch 7-taillight-006-small-.jpg
Old Jul 20, 2012 | 10:29 AM
  #123
BigBadLou's Avatar
Engine: TPI
To avoid littering this thread, just PM me. I can call you again later if we need to.
Old Jul 20, 2012 | 10:32 AM
  #124
BigBadLou's Avatar
Engine: TPI
Cool bat!!
So the wings are connected to the turn signals and flash with the red bulbs? You can keep that functionality, I don't think it will visually disturb it. It will work with my unit, no problem.
Lou
Old Jul 20, 2012 | 11:00 AM
  #125
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
Since I still havent gotten to install mine yet, whats it taking everyone to do theirs
Old Jul 20, 2012 | 06:26 PM
  #126
Dabesiv's Avatar
Mine was a little different to instal cause the wiring diagram wasn't right. But once i talked to Lou about it it was fairly easy. A few splices and some crimps and you're good to go
Old Jul 21, 2012 | 08:34 PM
  #127
Dabesiv's Avatar
After some trial and error with adjusting the mechanical flasher, I accidentally broke it. but now i have the electronic flasher and everything is working perfectly for me. Thanks a lot Lou for the product and some beyond superior support on this!
Old Jul 21, 2012 | 08:47 PM
  #128
bison999's Avatar
Car: 1984 Firebird S/E
Engine: 2.8 carbed
Transmission: Warner T5 5 Speed
Is it to late to request to be added on your list bad?
Old Jul 22, 2012 | 08:23 AM
  #129
Car: 1988 GTA
Engine: 400 CI
Cool bat!!
Lou
Yes. I just added 2 dual filament sockets and tied 1 of them into the center brake/directional sockets for each side. They're brake lights and also flash for directional. So I'm thinking the wing will light up at the same time as the center sockets with the STS. Great. Put me down for one. I have paypal.
Old Jul 22, 2012 | 09:05 AM
  #130
BigBadLou's Avatar
Engine: TPI
Glad to hear that yours is flashing as expected!
How much was the adjustable flasher? Got a link? I am working on one but still have one issue to iron out.
Lou
Old Jul 22, 2012 | 09:08 AM
  #131
BigBadLou's Avatar
Engine: TPI
It definitely is not too late. I got units pre-made now, sitting on the shelf, ready to go, if you'd like one. PM me for more information.
Lou
Old Jul 22, 2012 | 09:21 AM
  #132
BigBadLou's Avatar
Engine: TPI
So now you have 3 bulbs per side, that would work nicely.
I'll PM you my PayPal info. I can ship your STS unit first thing in the morning!
Lou
Old Jul 22, 2012 | 09:25 AM
  #133
Car: 1988 GTA
Engine: 400 CI
Lou
Well I haven't been in there for a while but I believe I now have 4 per side. It causes my directionals to flash fast but I plan on replacing the bat sockets with LEDs. That should solve the flashing problem. I will send it paypal as soon as I get your message.
Old Jul 22, 2012 | 09:27 AM
  #134
BigBadLou's Avatar
Engine: TPI
PM sent.
Old Jul 22, 2012 | 09:38 AM
  #135
Car: 1988 GTA
Engine: 400 CI
Payment sent.
Old Jul 22, 2012 | 09:43 AM
  #136
BigBadLou's Avatar
Engine: TPI
Payment sent.
Got it.
I am holding your unit in my hands right now, I am testing it before I ship it in the morning.
Thanks for the payment that went without a glitch.
Looking forward to seeing your bat flash! You can let it flash with the first (innermost bulb). If you use an LED, it will light up faster and look like another stage of the sequence.
Lou
Old Jul 22, 2012 | 09:53 AM
  #137
Car: 1988 GTA
Engine: 400 CI
Got it.
Yeah I would like it to work upon arrival!
Lou
That would be cool, like a 4 socket sequence. I have to see if they make bright LED arrays that fit the old sockets or I will just switch to some kind of dual LED socket (or mount 2).
Old Jul 22, 2012 | 09:57 AM
  #138
BigBadLou's Avatar
Engine: TPI
Yup, they do make LEDs with the 1157 sockets on them. They are not cheap (when WERE LEDs cheap? ) but they might be worth it.
Old Jul 22, 2012 | 12:19 PM
  #139
Dabesiv's Avatar
Lou
I just walked into the local pep boys, best prices for parts here. It was around $12, a little much, but oh so worth it
Old Jul 22, 2012 | 12:24 PM
  #140
Dabesiv's Avatar
Super bright LEDs has some 1157s for as low as $8 it's better then local shops charging $20 or more for one bulb
  #141
BigBadLou's Avatar
Engine: TPI
Wow, that is unbelieveably cheap. They used to cost $60 a year or two ago and they cost $45 last time I checked. $12 is a very reasonable price, I am happy to hear that.
Old Jul 22, 2012 | 10:14 PM
  #142
Billy7718's Avatar
Can you add me to the next batch?
Old Jul 22, 2012 | 10:40 PM
  #143
BigBadLou's Avatar
Engine: TPI
Billy, I got units ready to ship if you'd like one. I will PM you payment information.
Lou
Old Jul 22, 2012 | 11:17 PM
  #144
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Which ones would look best in our taillights? Obviously the "spider" style lights won't fit into the light housing. I'd prefer to keep the illumination looking right. Not just one bright bulb in the middle. I was looking at the P/N: 1157-x1W-G: 1 Watt High Power LED BAY15D Bulb with Stock Cover. Is that a good choice?
Old Jul 23, 2012 | 01:52 AM
  #145
Dabesiv's Avatar
I wish i could be of more help here. I have experience with the 194 bulbs but havent done any of the 1157s. I wish i could afford the spider like ones but Im still a kid in a sense and making a kids wages haha. Im getting ready to order the 19 LED bulbs in red with 100 degree light output. i thought about painting the inside of the reflector housing silver too but not sure if itll add any light to it. once i order them i can post a video of incandescent vs. the LEDS
Old Jul 23, 2012 | 05:47 AM
  #146
Car: 1988 GTA
Engine: 400 CI
Yeah it is. I just ordered them. Wasn't sure which would be best for my center light so I ordered the 19 and the 30 in the 100 degree angle.
Old Jul 23, 2012 | 11:15 AM
  #147
BigBadLou's Avatar
Engine: TPI
Question: is this a GM plug-in replacement flasher or did you have to splice it in and modify the wiring?
The one that I'm working on is a direct plug-in, no modifications necessary.
Old Jul 23, 2012 | 05:09 PM
  #148
Dabesiv's Avatar
It's direct plug in made by Dorman, it plugged in no problem and fit in the original holding spot too ( behind the choke light which seemed odd) . I believe the part number was 552 which is the dual pin and 550 was for the tri pin. I may have those swapped though
Old Jul 23, 2012 | 05:20 PM
  #149
BigBadLou's Avatar
Engine: TPI
Great, thank you so much for the information. Hopefully it will help others who need an adjustable flasher. This is so much cheaper than it used to be. And I spent countless hours making mine.
Old Jul 23, 2012 | 05:51 PM
  #150
Dabesiv's Avatar
You were extremely helpful with my wiring issues and were very fast about making a new diagram so I'm more than happy to help you and others make this an easier and cheaper project with any info I can
