Blown Acc Fuse Cause
Old Apr 26, 2012 | 04:33 PM
TheGr8erG00d's Avatar
First off, yes, it happens when I try to use my lighter. I pulled the lighter socket out and found that it rattled like crazy. I found a new used lighter assembly that was still in good shape and installed it. However, again, first time I pushed the lighter in it popped the fuse. Fiddle sticks.
Now, I'm not a smoker, but I do wish to locate the cause of this issue. I like to have everything in good running order. Everyone knows it's a common problem and it's all over our message boards, but does anybody know a good place to start with trouble shooting it, besides the socket since I've already replaced that? I scoured the boards and haven't found anything besides "replace the fuse, unplug your lighter," etc, etc.
I do have a few wire diagrams I can use to guide me, but if there is previously known trouble-making wire it would come in handy to know about it.
Thanks.
Old Apr 29, 2012 | 01:00 PM
Re: Blown Acc Fuse Cause
Anybody?
Old Apr 29, 2012 | 03:39 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Try plugging in your phone or MP3 player charger and see if doing that will blow the fuse.
This will isolate it to either the socket, lighter or whether you need to start looking else where.
Old Apr 29, 2012 | 03:48 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Put in a higher amp fuse.
Old Apr 29, 2012 | 03:56 PM
Paulo, that is brilliant. Madden, that is an awful idea. Risk burning up the wiring AND my car? That is a poor solution.
Old Apr 29, 2012 | 04:19 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Instead of a used socket, probably with the same issues, put in a new one from a parts store. You may have to use a different connector on your harness, it's just two wires - this is the route I took for mine...
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
thunder57
Nov 7, 2015 02:28 PM
usafirebird
Sep 29, 2015 11:58 PM
