car doesn't turn on
Car: 91 rs
Engine: 350 tbi with EBL
Transmission: t56!
Axle/Gears: 2.733
car doesn't turn on
i turn the key and there is nothing from the starter. checked all my wires as it was working before. as i had just done a auto to manual swap i checked the neutral safety switch. i have EBL installed so i connected my laptop and it shows that its in "D" drive so i clicked the switch but still shows im in "D" so i unplugged the switch and connected the two wires together but still the "D" stays on. so im guessing its not a power issue to the started but the computer thinking its in drive and not letting the car start. i followed the two wires to where i soldered them and no problems. i dont know where the purple and green (park/neutral switch wires) as it goes into the center console under the carpet. any help to what might cause this would be appreciated!
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Swap & Shop
Because you removed the automatic you need to connect the purple wire and the tan wire with a White stripe, NOT the green wire.
Happy Racing!
How bout those too scared to drive without headlights in the daytime
and the ones that need headlights for a little rain
Happy Racing!
Car: 91 rs
Transmission: t56!
Axle/Gears: 2.733
Re: Swap & Shop
the two thick wires coming from the auto shifter were purple and green unlike purple and tan/white shown in the pics on this site. is the tan/white wire found somewhere else? the car was running for a week and a half wired like this and wouldn't turn on if the clutch wasn't depressed so im guessing my green wire=tan/white wire?? i didn't mix up the reverse light wiring.
Transmission: 765R4
Swap & Shop
Its possible the PO changed some wires.
Happy Racing!
Happy Racing!
Car: 91 rs
Transmission: t56!
Axle/Gears: 2.733
Re: Swap & Shop
i ended buying a mini starter and a heat shield. when the car was auto there were times my car wouldn't start unless i waited 10 min so maybe the starter just died. its a summit mini starter btw
db057
Aug 11, 2015 10:11 PM
