Lighter; fuse blows
Old Apr 28, 2012 | 12:00 AM
joekonik's Avatar
Car: 1989 Camaro Iroc-z
Lighter; fuse blows
I hope this is an easy fix..it seems as if evertime I plug something into my lighter to charge it; zune, phone, etc. ..the fuse blows. I've never gone about anything like this before. Any suggestions?
Thanks!
Old Apr 28, 2012 | 12:24 AM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: Lighter; fuse blows
The socket is shorting out. Happened to me. I took it out and on the inside you should see tabs. Try bending them back a little, reconnecting then plug something in. Worst comes to worst, you can always just buy a new socket and replace it.
Theres 4 torque screws I think that hold the cover on then the socket should come out after unclipping the wires. Pretty easy fix.
Old Apr 28, 2012 | 06:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The cigarette lighter is a common problem on our cars (a search will provide more info). The pics in the following link might be helpful:
https://www.thirdgen.org/forums/inte...-i-remove.html
JamesC
Old Apr 30, 2012 | 10:40 AM
joekonik's Avatar
Thanks man! I took it out once and made sure everything was fitting tight but I think that one of the metal clips that comes in contact with the lighter is broken.. I'll see if I can get a good enough picture then I'll post it on here.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
64goatman
Sep 9, 2015 01:09 PM
