HID reverse light on my ThirdGen
Old May 20, 2012 | 09:07 PM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
At night I cant see to back up at all. To make matter worse, day or night it was as if people didn't know I was backing out and they would zoom past me. Pretty dangerous.
I picked up this HID kit for 39.95 from a local stereo shop. Its 35w and even fully warmed up it is still cooler than the incandescent's. I was a very easy swap, the included grommets fit perfectly in the hole.
This is how I wired it up, real simple and the ballast fit nicely in the area next to the reverse lights. I did have to cut just a little to get them to slip in.
BEFORE
Old May 20, 2012 | 09:09 PM
Engine: 2002 SS LS1
Re: HID reverse light on my ThirdGen
AFTER
Old May 21, 2012 | 06:49 PM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
wouldnt that melt your housing after excessive use?
Old May 21, 2012 | 06:52 PM
Engine: 2002 SS LS1
I haven't had it in long, but after install I left it in reverse for like 10 minutes and it was still cool to the touch. These bulbs are very cool when compared to incandescent bulbs.
Old May 21, 2012 | 07:23 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
H.I.D. "capsules" run much much cooler than conventional bulbs.
Old May 24, 2012 | 07:34 PM
brdofpry85ta's Avatar
Car: 1985 Trans Am
Engine: 6.6 at least
Transmission: T-56 (waiting)
Axle/Gears: 9" w/4.56 & spool (4 now)
what bulbs did you use.....
Old May 24, 2012 | 09:42 PM
mrrman's Avatar
wow, thats bright
Old May 24, 2012 | 11:17 PM
Engine: 2002 SS LS1
the bulbs are just generic 6000k that came with the kit.
Old May 25, 2012 | 11:25 AM
Car: 1992 RS 6spd
Technically they are called capsules, as they arent bulbs in the conventional sense.
Old May 25, 2012 | 11:28 AM
Engine: 2002 SS LS1
Are all HID capsules or just the ones in these cheap hid kits?
Old May 25, 2012 | 11:31 AM
Car: 1992 RS 6spd
They're all capsules. It doesn't matter if you bought them on ebay, or they came as OE on an M6.
Old May 25, 2012 | 01:17 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
.....This is how I wired it up, real simple and the ballast fit nicely in the area next to the reverse lights. I did have to cut just a little to get them to slip in.
How did you mount the bulb socket in the housing? Is that clear silicone holding it in?
Old May 25, 2012 | 01:25 PM
Engine: 2002 SS LS1
The black part going into the housing is a grommet included in the kit. It actually fit perfectly.
TheJoeY88
Dec 31, 2016 07:30 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
hokis
Aug 9, 2015 03:57 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
