Voltage gauge reading at 18 volts!
Old May 25, 2012 | 12:12 AM
806camaro's Avatar
Car: 1990 IROC
Ok here we go... I bought my 1990 IROC almost a year ago, and it's completely stock. The. Volt meter pegs out in the red zone at 18 volts, and it will move back and forth when the blinkers are being used. What's is causing my voltage to be this high. I never really cared before, but I'm gonna start running out of town a lot and do not want to get stranded. And yes it's been running like this the whole year I'm been driving it, and it's my everyday driver. Bad stock volt gauge? I would I test the alternator?
Old May 25, 2012 | 12:52 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Voltage gauge reading at 18 volts!
Measure the voltage with a test instrument.
Old May 25, 2012 | 12:43 PM
806camaro's Avatar
Car: 1990 IROC
I did this, voltmeter showed to be at 25.5 volts, even possible?
Old May 25, 2012 | 12:54 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
1. Remove alternator
2. Bring to autozone
3. Get alternator tested
4. Find out it is bad
5. Buy new alternator
6. Profit
Old May 25, 2012 | 02:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Check the regulator sense wire at the alternator.
Old May 25, 2012 | 03:08 PM
806camaro's Avatar
Car: 1990 IROC
Alright, this is my first time messing with a serpentine belt, and how do I get it off?! I mess with with a silver belt tensioner that had a torx fitting. That didn't do anything the torx bolt was coming out. So then I messed with the pulley right under the belt tensioner they bolted together, it has a 1/2 bolt head on, so I wrenched up to that and that bolt started coming out too. What am I sopposex to do?
Old May 25, 2012 | 03:31 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
It's been a while, IIRC, square hole- ratchet will fit. Don't recall if it's 1/2 inch drive..?...
Old May 25, 2012 | 05:01 PM
Car: '87 Camaro
PS-
The square that's offset to the right on the tensioner.
Old May 26, 2012 | 11:36 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You don't undo anything.
You put a long 1/2" breaker bar into the square hole in the tensioner and lever against the spring in the tensioner
until the belt is loose enough to get off the pulley
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
bamaboy0323
Sep 3, 2015 06:07 AM
