No wipers or turn signals
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
Im working on getting my 84 trans am ready for state inspection so I can drive it on the road. My issue is my wipers won't work and neither will my turn signals. I have brake lights and my hazards work. Does the lever need replaced or is it something else
Re: No wipers or turn signals
Well i don't have turn signals either (1991 Camaro Z28, L98/700R4) I didn't check my wipers but will very soon, Flashers work Checked all fuse with fuse tester. Now im at the convenice center, replaced hazard but i am missing two fuses or relays, or resistors, on the convenice center/panel. Get this went to the local GM dealer today and they no idea, it's not in their computer, and they haven't had parts books to look things up sence the 1980s, Guess I'll head over to NAPA tomorrow Good luck
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Turn Learn
Originally Posted by midge54
Does the lever need replaced……..
With the key in the RUN position use a voltmeter or test light (the type for testing for voltage, not a continuity tester) to probe the purple wire at the steering column connector located near the lower right of the column.
If there’s no power there post same.
If there’s power there probe the light blue wire at the turn signal switch.
Is there power there?
If not, replace the switch.
Happy Racing!
I Didn’t Jump The Start, The Flagman Was Late
MikkoV
Sep 9, 2015 04:25 PM
