I need some help. Bought a new wiring harness.
Car: 1988 Camaro, Holley 600 series.
Engine: 350 w/350 TPI heads
Transmission: 90+ 700R4
Axle/Gears: not sure
So I bought a new wiring harness from keep it clean wiring. They sent me a fuse box that looks a bit different from my old one and im wandering if I should keep it the same or use the old fuse box and relays and all that.
I need some help.. If someone could give me a detailed wiring diagram that would be great. I have the book for my car and understand the diagrams a decent amount its just I dont know which wires go into which plugs.
If someone could help that would be great,
Thanks.
Thanks.
Re: I need some help. Bought a new wiring harness.
All I need to know is what ports these wires go into inside the switches. Because they are not the same color.
Someone help?
Someone help?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
here is a link, you dont state what years or ecm service numbers and car options you are dealing with.
http://www.austinthirdgen.org/index.php?pid=19
Engine: Lb9
Transmission: M20
Hm. I have no idea. I have power windows, its an automatic, I have three buttons where my shifter is I think two are for the windows. Its an 88 and its a 305 fuel injected. How do i find the ecm? Thanks a lot for the link.
Engine: Lb9
Transmission: M20
if its a 88 Lo3 tbi should be a 1228063, is the harness you swapping just the interior? or engine harness with the fuse block ?
Its the whole entire harness. For the engine bay, the interior and all the lights.
So its all the switches.. There was a couple on my steering wheel.. Ill take a picture of the few things im confused about and then a picture of my new fuse box it see if I should stick with the old one.
The one pic is the same just top and bottom pic because I have no idea what it is. And it looks like the same thing that is on my new fuse box so wandering if even need that thing at all.
The new fuse box is the one on the left by the way.
Engine: Lb9
Transmission: M20
is it from painless or something ?
Engine: Lb9
Transmission: M20
since none of the new fuse box fuse locations are labeled you need to just decide what you want were. is there a issue with the stock one ?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Appears he has bought a generic aftermarket harness for the chassis ; not the engine /ECM you are referring to
Given what you wrote most would assume you have a new FACTORY harness for the engine bay / ECM
If you have a non factory harness you are on your own as far as having to read the factory circuit diagrams
and match them up to what ever wiring is supplied in your new harness
Car: 82 Z28
Transmission: T400
He is going to have to integrate the stock engine wiring with his new aftermarket harness Engine /ECM will remain standalone ( with 12V supply from the new fuse box) and only new wiring to engine will be the OP and temp sensors
Wires are generally labelled along their length as to their function and orginate at a marked fuse ( where required)
Im asking what that piece is also in the pic. It has a relay or something in it but my new fuse box has almost the same exact setup as that thing. It also has 30a fuses in it rather than the big metal ones for my windows.
There is a short in my car and I'm restoring it anyway so I just bought a new wiring harness. So almost everything will be new on it. So thats why I have a new fuse box.
Engine: Lb9
Transmission: M20
are you asking about the turn signal flasher ? or the relay.
the metal pieces that fit into the fuse holder are called circuit breakers.
86IROC112
Sep 7, 2015 01:37 PM
db057
Aug 11, 2015 10:11 PM
