bad relay?
Old Jun 14, 2012 | 09:23 AM
lakeport's Avatar
Car: 1988 GTA Trans AM
Transmission: 5 speed
bad relay?
I had a wiring problem that i have managed to fix, was posted in the general engine tech area, however I think i may have a damaged blower hi/low relay
the relay hums rather loud, but when key is turned to on, or car is started it stops
also the lights around the heat controls are on all the time
did i fry the relay, think i had the one ground connected to 12+, are these symptoms of a bad hi/low blower relay or something else?
thanks in advance to all
Old Jun 18, 2012 | 04:12 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Relay Likes To Sing By The Campfire
It sounds like you might have pinched a wire allowing power getting to the relay coil when it’s not supposed to.
Use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) to probe the wires going to it.
However be advised pin A, the
red wire is supposed to have power on it at all times.
Happy Racing!
I Didn’t Jump The Start, The Flagman Was Late
BumpaD82
Feb 26, 2016 02:57 PM
Johnoooooo
Sep 22, 2015 08:55 AM
Gunsbee
Sep 7, 2015 07:10 PM
Glowsock
Sep 6, 2015 06:40 AM
