Rear Light Malfunction
Old Jul 3, 2012 | 06:41 PM
madbomber824's Avatar
Car: 1986 Camaro
Engine: 350-Carb
Transmission: 700-R4
My 86 rear tail lights are not working properly. The only lights that work correct are the brake lights although the third brake light does not work at all. Took apart the third brake light and good bulbs and connections. As for the turn signal lights, if you have one on, both flash at the same time (similar to hazard). Running lights do not work at all and hazards only work when lights are on.
I ended up changing all the bulbs (figure i prob should since never has been done since i owned the car) and cleaned the bulb connections.
I think that it might be the turn signal switch. My camaro was originally a 2.8 v6 with tilt steering. I recently changed the turn signal switch in the tilt steering column and problem seemed to happen after i put it in. I bought the new switch from oreillys (part # S3246) which is a 10 prong male connector. I looked under the steering column and realized that the female connector is a 9 prong.
Is this the problem?
Old Jul 3, 2012 | 07:20 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Rear Light Malfunction
That very well could be it, how does one repair that?
Old Jul 4, 2012 | 08:23 PM
Car: 1986 Camaro
Engine: 350-Carb
Well i would need to find the correct turn signal switch i guess. Ill prob go round to the auto parts stores tomorrow to figure if they can get a 9 prong switch. Otherwise it is acting like a grounding issue.
Old Jul 5, 2012 | 12:10 PM
Car: 1986 Camaro
Engine: 350-Carb
all fixed, turn signal switch i had was correct. Ground wire was not grounded properly and was causing the issue.
Old Jul 5, 2012 | 10:55 PM
nWo Hogan's Avatar
Car: 89 Trans Am
Engine: 5.0
I have the same problem as well,and I'm slowly restoring the car. It must be that ground wire for the turn signal switch. Where is that ground wire located ? Thanks
Old Jul 7, 2012 | 02:17 PM
Car: 1986 Camaro
Engine: 350-Carb
the ground for the rear lights is a black wire from the left rear of the car. If you take some of the rear interior trim away from the car, on the driver side in the rear there should be a wire loom and follow the wires going to the electric hatch motor. There should be a black, yellow and possibly an orange wire. The black is the ground for the lights. That was the wire not properly grounded on my car.
Old Jul 7, 2012 | 05:14 PM
Edwardgp's Avatar
Engine: 454-350
thanks for reporting what you found.
Old Jul 8, 2012 | 06:10 AM
nWo Hogan's Avatar
Car: 89 Trans Am
Engine: 5.0
Thank you very much
Vintageracer
Jan 10, 2020 05:33 PM
BurlyChev
Aug 16, 2015 09:08 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
