Help gettting my electric fan to work on my 86 camaro
Old Jul 25, 2012 | 11:34 PM
my_86_camaro's Avatar
Car: 1986 z28 camaro
Engine: Chevy sb 305
Transmission: auto, 700r4
Axle/Gears: crap one-wheel wonder
Title says it all. I could really use some help, thanks
Old Jul 26, 2012 | 10:43 AM
xxZ28xx's Avatar
Car: 1988 Camaro, Holley 600 series.
Engine: 350 w/350 TPI heads
Transmission: 90+ 700R4
Axle/Gears: not sure
Re: Help gettting my electric fan to work on my 86 camaro
Well if its anything like mine it has two wires going into it. One I think may be a ground and the other one should go to a switch on the right side of your block.
But mine is wired into the ignition wire so when I turn my car to accessory the fan will come on. Just take the hot wire from the fan and find the hot wire going through the fire wall.. Should be a 10-12 gauge red wire and splice it in there.
Im just giving you a suggestion on how I did mine and it works fine :P Good luck!
Old Jul 26, 2012 | 12:23 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
You didn't give us exactly much information here. Good luck getting help with that approach.
TPI? Which fan isn't working? (TPI has two, that's why I'm asking)
But I'll be nice and provide a link to a troubleshooting article that might help you out: http://www.austinthirdgen.org/index.php?pid=36
Let us know what you find.
Lou
Old Jul 26, 2012 | 12:25 PM
BigBadLou's Avatar
Engine: TPI
Careful, that is incorrect.
The fans are powered through relays. Each fan has its own.
The switch in the passenger head is the cycling switch for the TBI and overheat switch for the secondary fan on TPI. That switch merely grounds the appropriate relay, it does not powe the fan itself.
Hope this helps.
Lou
Old Jul 26, 2012 | 08:02 PM
If it helps it has a carb
Old Jul 27, 2012 | 09:46 PM
Could anyone tell me how to just make it a toggle switch, so it turns on and stays on when i turn the key?
Old Jul 27, 2012 | 10:52 PM
BigBadLou's Avatar
Engine: TPI
If you still have the fan relay, just attach its ground wire to the block or chassis somewhere. That will make it run whenever the ignition is on.
Old Jul 28, 2012 | 12:06 AM
alright thanks for the idea, but where is the fan relay at?
Old Jul 28, 2012 | 09:20 AM
BigBadLou's Avatar
Engine: TPI
Have you not even glanced at the troubleshooting article I provided to you?
All you need to know is in there.
Old Jul 28, 2012 | 08:47 PM
Ya i did. Thanks
Old Jul 30, 2012 | 04:58 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
So you have "one" fan? The relay is by the drivers side fire wall. The switch that runs it is in the passenger side of the block below the number 6 cylinder (pretty sure your single fan is like mine on my 84). Make sure it's there and that there is a wire going to it. Sometimes they break or are cut when people don't realize what they are.
Old Aug 5, 2012 | 04:34 PM
Alright. Thanks everyone who posted for your help
Old Aug 5, 2012 | 06:26 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Could be that your motor for the fan has gone out. Or the relay has gone out. Like someone said before it is on the drivers side by the brake master cylinder. One way to check this is to find another relay thats similar on the car and swap them out, then turn the key on and flip the A/C switch on. This should turn your fan on, if it does then you need a new relay. If not it may be the motor.
If you want to convert to a manual switch its not that hard. You just need a 30 amp relay, a fuse, some wire, and a switch to do it. You can find tons of articles on how to do this if you search around some. Thats what I did with mine when I converted to dual fans. Ran one through the stock system, and put the other on a seperate switch I can turn on whenever, even with the key off. Good luck.
Old Aug 5, 2012 | 09:59 PM
I
Old Aug 5, 2012 | 10:00 PM
I got it to work it just wasnt gounded and i forgot what else but anyway i got it to work, but thank you for your post.
RazorN8
Jan 7, 2022 11:44 AM
Vintageracer
Jan 10, 2020 05:33 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Leggman1
Aug 6, 2015 04:15 AM
