new to camaros and need some help with wiring issue
Old Aug 15, 2012 | 08:47 AM
84Z28MAN's Avatar
I just recently picked up a 84 z28 camaro and it was running fine then the float in the carb hung up so I changed the carb and in the process of adjusting the carb(trying to crank it) I think I might have got the ignition to hot and smoke started coming out from under the dash. I was wondering if anyone else has had this problem and if they have solved the issue any help would be appreciated
Old Aug 15, 2012 | 08:53 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: new to camaros and need some help with wiring issue
Well first of all you will need to get under the dash and find out what the damage is.
Old Aug 15, 2012 | 09:03 AM
84Z28MAN's Avatar
I got under there and was looking around and found wires with melted surround but its from other wires I could not find any naked/melted wires
Old Aug 15, 2012 | 09:17 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
As Edward suggests, you will need to find the source of the smoke. If it happened during cranking, my guess would be on a component that is getting old and creating a lot of resistance in the path of the starter solenoid current and builds up heat. So you are not likely looking for a wire but the ignition switch, neutral safety switch, butt connectors or anything that can create a bad contact.
My best (and at the same time my worst) advice would be to:
1) grab a fire extinguisher
2) put on some goggles
3) lay under the dash (with the extinguisher within easy reach)
4) crank the engine and watch for smoke and listen for crack/pop/sizzle
Let us know what you find.
Lou
Old Aug 15, 2012 | 11:18 AM
84Z28MAN's Avatar
Ok thanks guys I will try that when I get home
Old Aug 20, 2012 | 07:21 PM
84Z28MAN's Avatar
i found out the aftermarket tach had shorted out and was causing issues now i need to figure out how to get the dash out to repair the wiring any ideas or write ups or how tos?
Old Aug 20, 2012 | 09:19 PM
BigBadLou's Avatar
Engine: TPI
Glad you found the problem.
I would recommend searching here on TGO for instructions on how to disassemble the dash. You might not even have to pull the whole dash, depending on where and how the tach is installed.
Old Aug 20, 2012 | 09:35 PM
84Z28MAN's Avatar
Yea the way they wired it they used the fuse for wipers the wipers still work but must have melted to the temp gauge wires cause when I turn the wipers on the temp gauge goes up and down with the wipers lol the burnt wires are in the harness behind the cluster I took out the cluster but there isn't enough room behind it to do anything
Old Aug 20, 2012 | 09:37 PM
84Z28MAN's Avatar
Also what is TGO?
Old Aug 21, 2012 | 06:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by 84Z28MAN
Also what is TGO?
Thirdgen.org
JamesC
Old Aug 21, 2012 | 08:17 PM
84Z28MAN's Avatar
i feel like a asshat lol
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Caspar
Jun 19, 2016 11:19 PM
djmarch
Aug 9, 2015 05:27 PM
