Cut outs switch mount
Old Aug 31, 2012 | 05:02 AM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
alright so i just bought my QTP electronic cut out exhaust, I was gonna have a rocker switch and mount it next to my hatch release, but it turns out this model has a toggle switch instead. so im not sure exactly where to mount the switch. any ideas here are welcome right now im looking at above the stereo where its available but not easy to get bumped into the on position. also where is the best place to go from the interior to engine bay on the firewall? ive seen a few things saying there is a hole by the brake master cylinder but havent taken apart the dash to check.
Old Sep 1, 2012 | 06:19 PM
Dabesiv's Avatar
Re: Cut outs switch mount
Bump
Old Sep 2, 2012 | 06:27 AM
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
As far as running a wire from the engine compartment to the interior, you shouldn't have to take your dash apart. There is a grommet with wires running through it on the firewall driver's side. Just follow the wires from your relays mounted on the firewall to see where they go through the firewall. I have sent several additional wires through that grommet without any problems. All you have to do is remove the panel above your pedals, 4 screws on my car, and send the wire in FROM the engine compartment TO the interior. Keep pushing wire through until you can see it under the dash.
Old Sep 2, 2012 | 07:04 AM
Dabesiv's Avatar
alright, thats easy enough. i think i might still have to pull the dash apart to mount the switch though. Thanks a lot though much help!
Old Sep 2, 2012 | 07:44 AM
Car: 1988 GTA
Engine: 400 CI
It depends on where you want to mount it. I am not familiar with the Camaro interior but on my GTA, there is a small plastic section along the bottom of the dash that is not connected to it. Works great for such things. (Pics 1 and 2). You could also just hang it from the bottom of the dash as in pic 3.
Attached Thumbnails Cut outs switch mount-switch-1-small-.jpg   Cut outs switch mount-switch-2-small-.jpg   Cut outs switch mount-switch-3-small-.jpg
Old Sep 2, 2012 | 02:56 PM
Dabesiv's Avatar
I wish i had those spots they would be perfect! as the pics show, my car has lights taking up all those spots, and i would hang it from the dash, but at 6'2" my legs are pretty much touching the dash as i sit so i would be knocking it with my leg all the time. originally i was gonna have a rocker switch that would mount perfectly next to the hatch release as the pics show, but QTP does a momentary toggle switch which would be a little awkward and easy to bump there. So for now the only place i can find is above the stereo, but i may check out those lights on the base of the gauges because it looks like maybe 2 of them arn't being used
Attached Thumbnails Cut outs switch mount-imag0965.jpg   Cut outs switch mount-imag0967.jpg   Cut outs switch mount-imag0968.jpg
Old Sep 2, 2012 | 02:58 PM
Dabesiv's Avatar
These are the areas above the radio im thinking of.
Old Sep 2, 2012 | 03:10 PM
Car: 1988 GTA
Engine: 400 CI
Those all look like good spots. I would rather take my console apart than my dash, but that's just me. I noticed in the second pic that you have a small piece of trim right under the steering wheel but I don't know what is behind it. Possible location ? (If your knees don't hit)
Old Sep 2, 2012 | 03:19 PM
Car: 1988 GTA
Engine: 400 CI
If it's just a momentary switch then you can get a pretty small one at Radio Shack that does the same thing. That little red button in one of my pics is a momentary switch for my anti-theft lockout. Just a suggestion because it really is tiny.
Old Sep 2, 2012 | 03:47 PM
Dabesiv's Avatar
i didnt think of that but i like that too. now qtp calls it a momentary switch but i think its a bit more since its spring held in the off possition and toggle one way is to open the valve and toggle the other way is to close the valve
Old Sep 2, 2012 | 04:48 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
I would change the switch to a rocker style switch and mount it IN the glove box on the wall , hidden and out of the way and most of all clean. but I mounted mine inbetween my window switches( freind drilled the hole before I could stop him )
Old Sep 2, 2012 | 06:46 PM
Dabesiv's Avatar
I wouldnt mind the rocker so much, its a lot less likely to be bumped on, but i want it easily accessible and the rocker would be a little harder to install and if i did a rocker id probably do one that lights up just for appearance reasons
Old Sep 2, 2012 | 09:08 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
you may be able to use a power window switch for this, it sounds like their switch is a momentary dp type
Old Sep 2, 2012 | 09:20 PM
Dabesiv's Avatar
A power window switch would work fine since it should be a DPDT switch but it still falls back to where to mount etc. I might just stick with the original toggle for now and go to a rocker once i put in another cutout.
jhawkeye
May 25, 2022 06:33 PM
Terrell351
Jun 13, 2021 01:13 PM
LittleFranks
Aug 20, 2015 03:55 PM
Elliswon
Aug 10, 2015 12:33 PM
