Trans Am fog light question
Old Sep 20, 2012 | 03:33 PM
89GTA_wFact.CD's Avatar
Car: 89 GTA Blk on Blk w/ T's
Engine: 5.7 TPI
My drivers side fog light isn't working , I put a new bulb in and still have nothing , the passenger side works fine , so could it be a ground problem ? While I was putting a new bulb in I also installed NOS fog light glass lenses that i bought a few years ago they really look nice and clear compared to my old ones so I know that the wires are hooked up correctly just wondering where I should look first for that one bulb not working ?? again the other side works fine
Old Sep 20, 2012 | 03:40 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Trans Am fog light question
Pull the bulb & see if you even have power going there. If not? Check to see if it is still plugged in. Follow the wires to find the plug.
IIRC, 1 fuse "controls" both sides. So if 1 side lights? Then you can rule out checking fuses.
Old Sep 20, 2012 | 03:47 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
It could also be a bad ground, let us know what you find out.
Old Sep 20, 2012 | 03:54 PM
Car: GTA
The Ground is in the wire plug, not through the mount.
Old Sep 20, 2012 | 04:15 PM
Edwardgp's Avatar
Engine: 454-350
Yes whats your point, I would still check it out.
Old Sep 20, 2012 | 04:26 PM
Car: GTA
My point is that I already said " Check to see if it is still plugged in" which would be checking the ground.
Your statement read as if the ground was something different, like through the mounting bracket.
Since what he was already mentioned to check, which included the ground, why did you even make your statement? Checking the plug would have already included checking ground. You obviously did not know that the plug includes the bulbs ground. I simply did not see any point in your post being made, since he was already told to check it. Unless you just enjoy rewording a statement of something that was already said.
Old Sep 20, 2012 | 04:48 PM
Edwardgp's Avatar
Engine: 454-350
Just wanted him to know his options, that would be check for power and do a continuity check on the ground.
Old Sep 20, 2012 | 04:53 PM
Car: GTA
Which was I said about checking power at the socket. Then at the connection (are power & ground both there?). Then following the wiring on up then check the switch, etc.
Old Sep 20, 2012 | 05:28 PM
Edwardgp's Avatar
Engine: 454-350
Oh well I hope he gets her fixed.
Old Sep 20, 2012 | 08:06 PM
Engine: 5.7 TPI
Thanks guys , I will let you know what it was , hopefully in the next few days , hope it's nothing big cause I just had some work done like new injectors, fuel filter, spark plugs , cap and rotor and pcv valve and it runs amazing !! so I gotta get this light fixed
Old Sep 21, 2012 | 03:12 PM
Engine: 5.7 TPI
Well I got it fixed , it turns out behind the lamp housing , someone at one time (could have been me) spliced the main wire together and that wire came loose , glad it was that easy
Thanks for the tips on what to look for
jaridjohn
Jul 8, 2024 03:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
