right turn signal wont work!
Old Sep 27, 2012 | 12:25 PM
brickman12's Avatar
I have a 92 camaro and the right turn signal is not working. when you hit the switch it will light up on the dash and stay solid but wont flash. the front right turn signal dosent come on at all and the rear turn signal will come on but stay solid. I have replaced all the bulbs so its not a buld out. Also when i turn on the flashers they all work just fine. Any ideas on what this may be? please help
Old Sep 27, 2012 | 01:01 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Re: right turn signal wont work!
The turn signal relay? I guess its a relay or something...usually on the fusebox? I dunno for sure, but you didnt mention checking that
Old Sep 28, 2012 | 06:52 AM
87rattler's Avatar
Car: 87 Iroc-Z28
There's a Flasher (little silver can shape, size of a C battery-ish) under dash. Not in fuse panel but to the right of the steering column, in my 87 anyway. Not sure if one side would work and not the other, if it's the flasher.
Old Sep 28, 2012 | 03:27 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
You already named your problem: the front turn signal does not come on.
The flasher (no relay on our Chevies) is load-driven so if the load decreases, so does the flashing rate. And a bulb out usually causes the flasher to stall and stay on.
Since you checked the bulb and it's good, check the socket, its connections and especially the ground.
Let us know what you find.
Lou
Old Aug 8, 2015 | 12:36 AM
middian's Avatar
Car: 1987 Camaro LT
Engine: 305 5.0 LG4
Axle/Gears: ?
I am having somewhat the same issue. Hazards work all the way around but when i hit the signal it will flash intermittently or just stay on with no flashes. Bulbs work apparently considering the hazards so?
Old Aug 8, 2015 | 04:44 AM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
last time this happened just replaced the flasher n issue solved.
Old Aug 9, 2015 | 12:53 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I would replace the flasher as mentioned and clean the part the bulb goes into with something abrasive . Front and back. If that does not work replace the bulbs. Front and back
That give you a proses of elimination. Now if that does not work you can look somewhere else.
Each side of the cars flasher lights front and back are tied in together. If something goes wrong with the right front it will effect the right rear and vice versa.
Old Aug 9, 2015 | 03:27 AM
middian's Avatar
Car: 1987 Camaro LT
Engine: 305 5.0 LG4
Axle/Gears: ?
ill look into that! how hard would this be?
Old Aug 9, 2015 | 03:28 AM
middian's Avatar
Car: 1987 Camaro LT
Engine: 305 5.0 LG4
Axle/Gears: ?
10-4! ill give it a go. Im just gonna go ahead and replace the bulbs theyre a bit old.
Old Aug 9, 2015 | 04:45 AM
Engine: TBI,5.0
Usually the curtice box is located under the dash just above your right leg. It swings open and down with hindges on the back. This is what it should look like. Just wiggle it a little and pull it strait out.
Old Aug 9, 2015 | 03:17 PM
middian's Avatar
Car: 1987 Camaro LT
Engine: 305 5.0 LG4
Axle/Gears: ?
I actually had to unscrew the whole thing. It was a pita but pretty straightforward. Anyways. Replaced bulbs, nothing, replaced flasher, bingo! Thanks for the help guys
specialized
Jun 18, 2022 09:26 AM
Caspar
Jun 19, 2016 11:19 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
