What is this wire?
Old Nov 24, 2012 | 08:35 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
What is this wire?
What is this wire? Im not sure where its supposed to connect. It does have 12 volts running to it.
thanks
Old Nov 24, 2012 | 09:21 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: What is this wire?
Originally Posted by patricklav
What is this wire?
Looks like the OP switch connector but your pic is TOO SMALL to see anything clearly.
Some more basic info would go a long way to identifying it
What are the wire colors?
Where abouts in the engine bay is it located??????
Old Nov 24, 2012 | 09:22 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Double post
Old Nov 24, 2012 | 09:44 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
OPSU, Oil Pressure Sending Unit.
Old Nov 24, 2012 | 09:45 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Here another pic. The wire is near the firewall by the distributor. The wires are orange, tan, and a greenish brown.
Old Nov 24, 2012 | 11:09 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Great. Thanks. Where does that plug into?
Old Nov 25, 2012 | 12:02 AM
The OPSU...
Old Nov 25, 2012 | 01:37 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Looks something like this:
http://img1.mlstatic.com/sensor-pres...40173_1603.jpg
Old Nov 25, 2012 | 06:18 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Six shooter was right both times. The part is located just above the oil filter. Looks like you are carbed so you do not need it.
Old Nov 25, 2012 | 06:03 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Yes, my motor is carbed. I am not getting any power to anything (another thread) ; starter, headlights, radio when i turn the key and cant figure it out.
The OPSU wire has 12 volts running hot to it. Does that make sense? If its just a sensor i wouldnt think it would have 12 volts hot all the time there. im saying this because it could be the reason im getting no power to my fuse block and power to this sensor and the wores are all messed up.
Old Nov 25, 2012 | 08:54 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
The oil pressure sensor is integrated with an oil pressure switch which powers the fuel pump. That's why you see power on the incoming wire.
Old Nov 25, 2012 | 09:17 PM
12V constant at the OPSU plug is a good thing, that's how it's supposed to be.
Old Nov 25, 2012 | 11:24 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If it has 3 wires then one of the wires is for the oil pressure gauge
Old Nov 25, 2012 | 11:25 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Old Dec 18, 2012 | 03:14 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Thanks guys.
Just got back to this issue. My engine is carbed so i guess i dont need the OPSU (post #9), however i would like to have some idea as to what the actual oil pressure is. If i install the sensor above the oil filter can i assume that will give me an accurate oil pressure reading.
thanks
Old Dec 18, 2012 | 03:41 PM
BigBadLou's Avatar
Engine: TPI
If you keep that connector on the OPSU, you will have a good oil pressure reading on the dash. You can ignore the power wires on it if you don't need them.
Old Dec 20, 2012 | 09:31 AM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
thanks for the help
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
