How to wire alternator?
Old Dec 12, 2012 | 11:25 PM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
CS style and I mean from the fuse box to the alternator. Some of you know that Im having problems with my 92 z28 when I apply the brakes or turn on the headlights the voltage drops found out some wires had bad connections but it didnt solve the problem so yesterday I traced all the wires in the engine bay ( carb'd motor lucky me lol ) and found out that the alternator pig tail have one red wire goes to the 12 volt and the other is purple instead of brown going through the firewall connector and I remember it should be a brown wire so I searched for the brown wire in the big connector in the firewall and didnt find any and this purple wire have current so I was thinking I will rewire the alternator from the the fuse box
Old Dec 13, 2012 | 12:25 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: How to wire alternator?
get a good audio type wire that has good copper wire, very fine stranded and I use #4 wire to make sure a good current flow. You can look at the type of lug and get a small piece of 3/8 copper wire and solder it and then hammer it flat with a shrink wrap cover and then drill the hole the exact size to the lug and it will work better especially with a higher output alternator. Remember, the audio guys use the best wire out there. It is all I use. I put my battery in the trunk and used 0 gauge and my lights are brighter.
Old Dec 15, 2012 | 07:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by 92-Z28
CS style, I was thinking I will rewire the alternator from the the fuse box
http://alternatorparts.com/cs130_sbpage3.htm
Old Dec 16, 2012 | 08:26 AM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
I already found an old topic and got the answer there thanks
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
