Headlights close fine, not opening.
Old Feb 3, 2013 | 04:46 PM
99olo's Avatar
Car: 1982 Pontiac Trans-AM
Engine: 283
Transmission: Saginaw 4 Speed
Problem: '82 T/A lights not popping up- motors work great, however.
If I go ahead and turn on the lights, then manually raise the lights, and kill the lights, they'll go down in an instant.
I'm a little stumped, and searching has brought me no where.
I figured I'd see other's inputs on the matter; also, who're you rootin' for in the super bowl?
Old Feb 3, 2013 | 08:13 PM
99olo's Avatar
Engine: 283
Re: Headlights close fine, not opening.
https://www.thirdgen.org/forums/elec...t-flip-up.html
After a few hours of looking, I found this; and I've found that my isolation relay is clicking.
Alright, thanks me.
I'm such a great guy.
Let's see if this helps... tomorrow.
Old Feb 9, 2013 | 06:03 PM
99olo's Avatar
Engine: 283
Guess not.
Anyone have a clue which connectors do what? (I'm sure you do)
I know that B is the power for running the motors down, but what are the others?
This would be a great help, anyone?
Old Mar 4, 2013 | 10:44 PM
locutus918's Avatar
Car: 89 formula firebird
Engine: formula 305 TPI
Transmission: 5 speed
Axle/Gears: 3.45
on my 89 they just reverse polarity mine failed to where both would close but only one would raise from the cost of the module 225 i just bought 2 toggle switches to reverse polarity was much cheaper and works no issue if you dont mind the custom wiring
Old Mar 4, 2013 | 11:00 PM
88formula305tpi's Avatar
Car: 1988 Firebird Formula WS6
Engine: 305 tpi lb9
Axle/Gears: 3.45
I would need a schematic to help you but I had an intermittant issue with mine not working, and once i popped my hood to go turn them up manually they would pop up? I already rebuilt the motors a few years back with a kit from topdownsolutions and figured there was a loose connection somewhere else. I checked all the wiring and ended up trying this free fix after a couple nights of messing around. It ended up solving my issue of having to bang on the dash or slam a door to get my headlights to come on now and then.
https://www.thirdgen.org/forums/elec...air-video.html
Old Oct 8, 2013 | 02:12 PM
99olo's Avatar
Engine: 283
The problem was; malfunctioning isolation relay. Seemed to work, however, did not send power properly.
Also, 2 bad actuator relays. If your lights close, that's cool and all, but that doesn't mean your actuator relays are any good.
GTAman
Mar 15, 2019 11:40 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
CORV3TT3
Aug 23, 2015 11:26 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
