89 tach over reading
Old Apr 8, 2013 | 01:35 AM
pure1959's Avatar
My tach over reads badly whats the cure?
Old Apr 8, 2013 | 12:03 PM
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Re: 89 tach over reading
It could be from a v6 car and is off because of that. The tachs are different between v6 and v8 cars. We really need some kindve info about the car and when it started doing this for us to even help you.
Old Apr 8, 2013 | 02:31 PM
pure1959's Avatar
The car is an 89 iroc 305 tbi.
Old Apr 8, 2013 | 09:14 PM
M G Brewer's Avatar
Car: 1988 IROC-Z
I got an '89 5.7tpi
and its doing the same.
Old Apr 16, 2013 | 02:16 PM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
i was watching a story on tachs on 2 guys garage, they said if your tach is going out, it will start to read higher than it should first, then go out later
Old Apr 16, 2013 | 03:37 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Its not the tach. There is a small chip that is not operating correctly. You'll need to solder in some resistors to correct the high reading. But given the fact that you have a v6, Im not too sure if the repair can be applied.
https://www.thirdgen.org/forums/elec...meter-fix.html
Old Apr 16, 2013 | 03:38 PM
I just saw that you posted 89 IROC 305. So go to the provided link and follow the instructions. Good luck man.
Old Apr 16, 2013 | 10:18 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
89 IROC 305.
Repair instructions are for the troublesome 90 -92 tacho
Hotrodboba400
Dec 10, 2019 07:07 PM
eustodp
Sep 20, 2015 05:09 PM
TrevinE
Sep 14, 2015 03:20 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
