Tach not working on instrument panel clusters??!!
Old Apr 26, 2013 | 06:00 PM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
Since I bought my 1992 camaro 6 months ago the tach gauge on the cluster didn't work. It would jump up a bit as soon as the key was turned on but never did any more than that. I recent had and iac problem and had an obd 1 scanner/tester hooked up and with the engine running I did get an rpm reading. Well I figured the cluster was just bad so I let it go until last week when my speedometer took a dump. So I got a cluster from a junkyard and put it in. The speedometer worked and still no rpm gauge?? I took it out because the fuel gauge was bad on the junk yard cluster. So I bought one cheap on eBay. The speedo worked and so did all the other gauges except the rpm tach. The guy I bought it from told me it worked when it was In his car. So... Is it possible I have 3 clusters with bad tachs or do you think there is a wire problem?? But like I said, I got a rpm reading with the scan tool hooked up to the obd 1 port. Not sure where to start. Please help
Old Apr 26, 2013 | 06:11 PM
jacobd32's Avatar
Car: 1984 camaro z28
Engine: 305 for now
Transmission: t5 for now
Re: Tach not working on instrument panel clusters??!!
have you checked where it hooks into distributor cap? if not look at cap you will see 2 wires running into a box sticking off it between 2 spark plug wires theyre labeled on cap as batt and tach make sure the tach is hooked up good and isn't loose
Old Apr 26, 2013 | 06:21 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Since youre getting a rpm reading on the scanner you know the wiring between the ECM and engine is fine. Chances are the wire leading to the cluster is damaged and just not relaying the signal to tach. Chances of having 3 screwed up tachs in a row is pretty slim.
http://www.austinthirdgen.org/index.php?pid=19 should help you in tracing the problem wire.
Old Apr 26, 2013 | 06:26 PM
Yea that's what I'm thinking
Old Apr 26, 2013 | 06:28 PM
So just the white wire from distributer to the ipc??
Old Apr 26, 2013 | 06:29 PM
What would I have to do for an auto meter tach mounted on dash???
Old Apr 26, 2013 | 06:44 PM
travis401's Avatar
Car: 91 Camaro RS
You should have a white wire on the ignition coil that runs straight to the cluster for the tac. Id start at the coil and work back from there.
Old Apr 26, 2013 | 06:56 PM
Awesome. Will do. Thank you
Old Apr 26, 2013 | 07:04 PM
jacobd32's Avatar
Engine: 305 for now
it will be the same as the stock tach. even the wire should work then just the ground and to the ignition. check out youtube there are some step by step vids on there
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
tnrednneck
Aug 13, 2015 08:57 AM
stalkier
Aug 7, 2015 04:49 AM
