Cruise control and brake switch question
Old Apr 29, 2013 | 08:48 PM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
I am working on installing a TCC lockup kit. I am looking at the two switches at the brake pedal. One has 2 wires and has a vacuum hose on the back of it. I think this is the cruise control brake cut off switch. The other has 2 connectors 1 with 2 wires and the other with 3 wires. I think this is the brake switch for lights and the TCC switch.
Here is my question.....
The manual says the brake switch is a pink/black and purple wire, but it is on the cruise control switch, not the brake switch. Is it possible that the two 2 wire connectors were put on the wrong switch? They look as if they would fit, ie. same clip for the wires. I know either would work, but the cruise control switch is broken and I am not using cruise right now. The other 2 wire connector has thick light blue and orange wires, but I can't find reference for those two wires.
Old May 6, 2013 | 07:36 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
OK Team, Take A Brake
To find out which switch is which, press one at a time by hand, while backed up near your garage or other reflective surface which can show when the brake lights are illuminated.
Happy Racing!
Spin Me This Week . . . I’ll Spin You Next Week
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
