fuse by battery blew on me, is this related?
Old May 12, 2013 | 10:53 PM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
lol so today while i was waiting for food at mcdonalds my car shut off on me and i had to push it out of the drive thru line
Took me a while to figure it out but the fuse next to the battery ended up blowing.
about a week ago i decided to jumper my foglight switch due to one of the wires not getting 12v, and have been running my foglights like this for a few days.
Can anyone tell me if the foglight switch wiring is in anyway connected to the fuse by the battery?
After this im kinda hesitant to run the fogs, but am not sure if there is any correlation, since its been about a week now and they seemed fine aside from the .7 idle voltage drop
If its not at all related to the fogs, what can i check that might of caused the fuse by battery to blow?
really appreciate any help guys thanks
Old May 14, 2013 | 09:52 PM
Stallion's Avatar
Re: fuse by battery blew on me, is this related?
Do you know where that fuse by the battery goes to? Usually, that will trace will the problem is coming from along that wire.
Old May 14, 2013 | 11:03 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Hi John,
the fuse by the battery powers your ECM, MAF relays and of course the fuel pump, which explains why your engine died when the fuse blew.
Either of the relays or the fuel pump itself could have caused the fuse to pop. You won't know until it pops several times and you find the common denominator.
All lights are on a different circuit which is separate from the ECM and fuel pump power feed.
Hope this helps.
Lou
MM2Robinson
Oct 1, 2017 09:16 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
z28joe2
Sep 28, 2015 05:54 PM
Johnoooooo
Sep 22, 2015 08:55 AM
gta892000
Sep 16, 2015 12:37 AM
